Author: Subject: Hydraulic fittings supplier?
bigandy
posted on 15/2/11 at 02:17 PM Reply With Quote
Afternoon all,
Does anyone know of a Hydraulics type fittings supplier that doesn't mind taking orders for a couple of small parts? I'm after a couple of 1/8" BSPT male to 7/16" JIC male adapters (plated steel or brass). Apparently they are not very common, and the local suppliers near me won't order them in
andy
Dammit! Too many decisions....
Mr Whippy
posted on 15/2/11 at 02:28 PM Reply With Quote
linky
there's loads, just paste the fitting description into google
god my spelling has gone to the dogs...
kept rereading that and another mistake!
[Edited on 15/2/11 by Mr Whippy]
nitram38
posted on 15/2/11 at 03:27 PM Reply With Quote
Russ Bost on here
daviep
posted on 15/2/11 at 03:29 PM Reply With Quote
Originally posted by bigandy
Afternoon all,
andy
Just to be pedantic you are looking for JIC -4 (pronounced dash 4 )to give it the proper designation
Come on Whippy read the description properly!
I'll have a rumage at work but if we have anything it will probably be npt ?
Davie
Mr Whippy
posted on 15/2/11 at 03:32 PM Reply With Quote
not my fault he doesn't know what he wants...
daviep
posted on 15/2/11 at 03:47 PM Reply With Quote
I was refering to the T at the end of BSP your link was to BSPP fittings
Davie
daviep
posted on 18/2/11 at 12:06 PM Reply With Quote
Are you 100% sure you need 1/8" BSP? 1/8" BSP and NPT are extremly close, NPT is 27tpi and BSP is 28tpi
Had a rummage at work yesterday, wasn't entirely succesful although I did find enough adaptors to go from JIC -4 to 1/8" NPT (JIC-4 x 1/4"NPT nipple + 1/4"NPT barrell + 1/4" NPT x 1/8" NPT nipple) to total length 80mm
Sorry didn't have the right fitting but let me know if these are any help.
Regards
Davie
bigandy
posted on 18/2/11 at 12:24 PM Reply With Quote
Thanks for looking Davie.
The fitting has to be a BSPT fitting, as it is going into a cast zinc housing on a pressure sensor, and the datasheet explicitly states that other fittings (especially BSPP, and NPT) fittings hsould not be used.
I think I've found a source from a supplier down south though, just waiting on a price from them
daviep
posted on 18/2/11 at 01:16 PM Reply With Quote
No problem, sorry I couldn't help
