Author: Subject: Locost Grp rear panel
sdh2903
posted on 19/2/11 at 05:36 PM Reply With Quote
After a break from building whilst building myself a garage (in the winter, in glasgow I need to get cracking again. I'm after a GRP rear panel for a locost (i'm not building a locost but very close size wise).
I know there are several companys out there producing GRP and have been trawling for quite some time, but i'm after one that comes complete with the infills in front of the rear axle (i like to call them 'ears'
The saturn one below is exactly what i'm after but thats for a haynes and wont fit with the upper tubes of the chassis
Does anyone out there produce one like this for the locost? I know i have the option of making an ally one but thought i'd ask first
cheers
handyandy
posted on 19/2/11 at 06:16 PM Reply With Quote
Just a thought...why not remove/reposition the upper tubes?
or....if your chassis is the correct width to accomodate the Saturn GRP tub, you can "cutnshut " (without needing to reapply any new fibreglass ) the GRP to make it fit, this would be in the area just below the roll bar mounting plates, not ideal but I have seen it done using the saturn tub.
cheers
andy
sdh2903
posted on 19/2/11 at 08:04 PM Reply With Quote
cheers
andy
With regards the saturn one, i must admit have considered removing bits etc, but If i followed the same route as the haynes boys to make it fit with the rear bracing etc then i would have to change fuel tank, which I dont really want to do.
I dont mind modifying the panel but dont really want to start chopping the chassis bits.
