Author: Subject: Cat needed??
antwan
posted on 22/2/11 at 08:55 PM Reply With Quote
Cat needed??
I have an M42 engine from a BMW 318is 1994/1995 engine. Installing it in an MNR. I understand that the emissions limits are slightly lower than todays limits but anyone have a clue if I will get away without a costly (and ugly) cat converter?
The engine is running a completely standard fuel injection system.
Ta
big_wasa
posted on 22/2/11 at 08:59 PM Reply With Quote
You will need one if the engine was made after aug 1995
antwan
posted on 22/2/11 at 09:01 PM Reply With Quote
Result! Checking the V5... Car born in 02/1995. Not questioning ones knowledge but how sure are you on this?
adithorp
posted on 22/2/11 at 09:10 PM Reply With Quote
If the engine is pre Aug95 (and you can prove it) then the emmision test is CO<3.5% and HC<1200ppm at idle. Those are the pre cat' limits. It should run somewhere around 0.5-1.0% co without a 'cat, so no cat' needed.
http://jpsc.org.uk/forum/
antwan
posted on 22/2/11 at 09:13 PM Reply With Quote
Great news thanks chaps. It will make for a much cleaner installation.
ReMan
posted on 22/2/11 at 09:21 PM Reply With Quote
Check 4 yourself too
http://www.businesslink.gov.uk/Transport_files/124_IVA_M1_Inspection_Manual_Version_1010.pdf
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
big_wasa
posted on 23/2/11 at 08:51 AM Reply With Quote
when looking at the above you need to know your kit will not be on there data base hence aug 95 and not 92 but you will need proof.
