orton1966
posted on 27/2/11 at 06:47 AM |
Sprockets - Where, How To Have Them Made?
I needed some non standard sprockets for a kart/buggy I have made for my son so I’ve just drawn some in solid-works and because they’re not being run
at any kind of speed or load I’m just going to have them water or laser cut from mild steel.
Now my real question, I’ve got to make a chain diff for the BEC-Midi I’m building, it’ll probably be based on a fiesta/Escort or MX5
limited-slip-disk. Obviously part of this will involve sourcing sprockets with the right amount of teeth and a centre-bore & pcd to suit the diff.
Where have other builder sourced these and at what kind of price?
Or could I do something similar to the above and have it machined or water-cut then anodised to harden the surface?
[Edited on 27/2/11 by orton1966]
posted on 27/2/11 at 07:16 AM |
This supplier makes sprockets for the Frazer Nash club
Any ratios, axle size or key size. If you need new sprockets Contact Simon Blakeney-Edwards 07949 170632 or 01934 861000,
email:edsmotorsport@btconnect.com
[Edited on 27/2/11 by britishtrident]
ReMan
posted on 27/2/11 at 07:55 AM |
These have been around forever.
Nice folk i see at bike shows jumbles etc
http://www.sprocketsunlimited.com/
www.plusnine.co.uk
FASTdan
posted on 27/2/11 at 08:44 AM |
You can buy standard plate wheels in all sizes for not much money with a pilot bore. See cross and morse pdf catalogue online. Just need the bore
opening up and holes drilling.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
liam.mccaffrey
posted on 27/2/11 at 09:08 AM |
hbc gears
Build Blog
Build Photo Album
grassracer
posted on 27/2/11 at 09:41 AM |
JB Gears in Wetherby 01937 845030. John is a top bloke, keeps blanks for most applications on the shelf with a 40mm 'pilot' hole. He is
also able to drill the bolt holes etc at very little extra cost.
I bought one last week and had it drilled to suit a 100mm sierra cv joint, cost me under £30 inc drilling and postage.
He is also very good for front sprockets for BEC applications
Don't bother looking for a fancy website there isn't one, just give him a ring
BobM
posted on 28/2/11 at 06:19 AM |
The RGB guys have used B&C Express for years, I recently got mine from
Talon Engineering. Both provide good service, Talon were a bit cheaper. I think it was 30-odd quid for hardened
alloy sprocket to fit the Quaife diff also with lightening holes and cut in half to allow fitting/removal without splitting the chain.
Not very Locost but very BEC
carpmart
posted on 28/2/11 at 09:03 AM |
Seconded for John at JB gears, he is brilliant!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
carpmart
posted on 28/2/11 at 09:04 AM |
I also use B&C for the rear sprockets and my chains, they offer a great service!
'94 MX5 MK1, 1.8
NS Dev
posted on 15/3/11 at 08:12 AM |
3rd for JB gears, excellent service and price
