Author: Subject: Car lift storage
Benzine
posted on 13/3/11 at 08:39 PM Reply With Quote
Car lift storage
So you want to store a car above another car but can't afford the above ^
Any ideas on locost car storage? The car on top would be stored long term and it doesn't matter if it takes a couple of hours to get it up there (as opposed to pressing a button and hearing some whirring for 30 seconds) I've got a new workshop with oodles of height and it would be great to free up some more floorspace.
Best idea wins a pie.
mookaloid
posted on 13/3/11 at 08:58 PM Reply With Quote
Easy - you just need a full size one of these
stevegough
posted on 13/3/11 at 09:04 PM Reply With Quote
Might take more than a few hours, but you could dismantle it, and then rebuild it on the upper platform. Then when you want it down again, all you have to do is do it again.
......do I get a pie?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
oadamo
posted on 13/3/11 at 09:14 PM Reply With Quote
dig a big pit drive it in then board over it
or just use a couple of cranes lifting a platform
[Edited on 13/3/11 by oadamo]
HowardB
posted on 13/3/11 at 09:16 PM Reply With Quote
have you got a mate with a beaver tail?
if so just build a mez floor, then drive onto the beaver tail, add some ramps and drive off onto the mez.
Otherwise do it the long way, build very long ramps up to the mez floor,..... =)
I can think of other solutions, but they mostly involve belief in steel fabrications,.. and access to winches
not a lot of help I know, but seriously, the first thing to know is how far off the ground you want the upper car?
Howard
Benzine
posted on 13/3/11 at 09:21 PM Reply With Quote
no access to beaver tail lift, cranes, forklifts etc
so it clears the lower car by, say, 6 inches. Something like 160cm
[Edited on 13/3/11 by Benzine]
PSpirine
posted on 13/3/11 at 09:38 PM Reply With Quote
I can think of a few but given that I think you can get one of these lifts for about £700, alternative solutions wouldn't be too far off (a few hundred quid) but would be crap in comparison. You'd need 4 winches and a lot of beefy steel. Winch the car up along a 4 post frame, then simply prop up the platform by inserting steel tubes into the posts.
