noc231073
posted on 18/3/11 at 04:43 AM |
Hayabusa clutch slave cylinder
Any one recommend a good clutch slave cylinder for a gen 11 busa
As the one supplied with my Mk is crap quality
Anyone use extremes or is there any other options
[Edited on 18/3/11 by noc231073]
SJL
posted on 18/3/11 at 10:07 PM |
I am using the Nova Racing/SBD/Extreme/Radical one.
Its made by Nova but branded to whoever sells it.I had to use it as I am using the same suppliers dry sump on mine so the pump goes where the original
water pump is and you have no choice but to use the appropriate slave as in my case the Westfield one.
I have the WF supplied bits still but from what I have read the pedal ratio isnt great using it (in a Westie certainly) if you want to make an offer
MikeFellows
posted on 4/8/11 at 01:24 PM |
did you sort one out for a gen 2 as im looking for one now
or can anyone confirm they are the same as a gen 1?
fimi7
posted on 4/8/11 at 04:20 PM |
The Nova Racing/SBD/Extreme/Radical one is the same for both Gen I and Gen II, biggest differences between the engine is in the heads and the fuel
injection went from 4 to 8 injectors.
Works well, fit a finish is good. I got my from SBD.
--- Ali
