dunk3
posted on 19/3/11 at 10:22 PM |
what to cover MDF with
I have made a boot cover for my mk indy out of MDF, what is the best thing to cover it with. or can you paint it,
[Edited on 19/3/11 by dunk3]
posted on 19/3/11 at 10:27 PM |
very thin foam from Woolies and some vinyl works for me.
mad4x4
posted on 20/3/11 at 01:12 AM |
I found that a camping mat from the hike shop is a good hi-density foam that works well under vinyl.
Used this under the vinyl on my dash and it is firm but squashy and can be shaped easily and is cheap.
Scot's do it better in Kilts.
snapper
posted on 20/3/11 at 06:46 AM |
Slightest bit of damp and MDF blows, I would recomend marine ply for your cover.
I have used camping mat for firmer feel, yoga mat for softer, covered with vinyl
I eat to survive
I drink to forget
Daddylonglegs
posted on 20/3/11 at 07:10 AM |
I agree with snapper, MDF is terrible for taking on moisture! Either marine ply or at the least WBP (Weather & Boil Proof - i.e. external) or
maybe normal but treated first.
HTH
Hammerhead
posted on 20/3/11 at 09:12 AM |
Out of interest, why are people covering with foam? Why not just vinyl straight on marine ply?
posted on 20/3/11 at 11:00 AM |
mdf is so bad with moisture that even paint blows the edges!
Mr Whippy
posted on 20/3/11 at 11:07 AM |
you could wrap the MDF in cling film and tape before covering to help keep out moisture
Antnicuk
posted on 20/3/11 at 11:27 AM |
It gives a nice padded OEM feel. I did it with my dash.
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
blakep82
posted on 20/3/11 at 11:55 AM |
i've got a rabbit hutch/hen house, covered with about 1.5 square meters of MDF covered in roofing felt, was fine when it went on, its now
doubled in thickness and nearly too heavy to lift with hand.
use marine ply instead!
MDF is basically paper
[Edited on 20/3/11 by blakep82]
________________________
stevegough
posted on 21/3/11 at 07:45 PM |
I agree with all that's been said about MDF - I made a Dovecote out of MDF last summer - and I gave it three coats of yacht varnish, then the
outside was further primed, undercoated and 2 coats of lovely powder-blue paint. The blue bit is ok at the moment, but the panels (floors which had
just yacht varnish) have swollen quite a bit.
My boot cover is made with varnished ply, then covered with just black Vinyl.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
