SALAD
posted on 21/3/11 at 05:36 PM |
XE pick-up pipe question.
Does anyone know the correct gap between the bottom of the sump and the pick-up pipe on a Red Top??
matty h
posted on 21/3/11 at 05:44 PM |
Not sure on the correct distance but be careful I have a 2.0 8v vauxhall engine which I fitted a QED sump to and put some of that carbon build up
cleaner in it first run out and the oil light come on,chap that rebuilt it said it had been starved of oil as you could see a mark on the bottom of
the sump from the pick up pipe.![](/images//smilies/shocked.gif)
SALAD
posted on 21/3/11 at 05:48 PM |
Was that with the corresponding QED pick-up too?!
I've chopped my sump and now need to shorten the pick-up......and it's not like I forgot to measure the sump before abusing it or
anything......![](/images//smilies/shocked.gif)
stevegough
posted on 21/3/11 at 06:26 PM |
I can't answer your question, but when I chopped my sump on my XE, I simply bought a shorter pick-up pipe from QED. I hasten to add, that was
after trying to shorten my pick-up pipe - I couldn't re-weld it without pinholes
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
donn006
posted on 21/3/11 at 06:48 PM |
sump
hi ive got about 3/5mm clearence on mine and had no problems
matty h
posted on 21/3/11 at 07:10 PM |
Yes full QED set up so I think you need to be careful with the sump gasket you use.
perksy
posted on 21/3/11 at 07:25 PM |
5mm is fine
Can be checked by a 'dry build' using Plastercine to check the clearence
Have heard of a couple of folks have had the same issue with the QED sump set-up, but not sure what gasket/s they were using
NS Dev
posted on 22/3/11 at 08:39 AM |
ditto about 5mm, its not too critical, just don't go less than 3mm. As above, a dry build with plasticine is a good idea
SALAD
posted on 22/3/11 at 06:18 PM |
Excellent, 5mm it will be. Thanks chaps.
