Author: Subject: who can identify these break callipers
hootsno1
posted on 26/3/11 at 07:15 PM Reply With Quote
Hi all
i was given these break callipers today and was told they were for a sierra they came out of a garage that once housed a cossi?
I put them up against my donor ones and the body is bigger, the pad carriers are the same and all the bolt patterns are the same.
First one to identify them gets a GOLD STAR!!!
Many thanks
Mark
gavin174
posted on 26/3/11 at 07:22 PM Reply With Quote
Mark
there are different size front calipers on the cosworth...
240mm disc I think
hootsno1
posted on 26/3/11 at 07:26 PM Reply With Quote
if they are for the cossi i will buy some disk but im not shore they are cossi ones
mcerd1
posted on 26/3/11 at 07:50 PM Reply With Quote
2wd sierra cossie's have 4 pot calipers that suit 283mm vented discs and totaly different hubs
4x4 sierra cossies, escort cossies and granada 24v cossies have single post front calipers and suit 278mm vented discs (I think these might be a 60mm piston too ? )
normal sierra's with ABS, V6's or 4x4 have single pot calipers with a 60mm piston to suit 260mm vented discs (also used on some RS turbo's)
most of the rest have single pot calipers with a 54mm piston to suit 240mm vented discs (although the 1.3;s and some 1.6's had 240mm solid discs)
I've got ones for 260mm discs here and they have different numbers from your pic....
[Edited on 26/3/2011 by mcerd1]
ickle
posted on 26/3/11 at 08:54 PM Reply With Quote
most motors factors should be able to id it for you..
if your struggling i can phone amk or brake enginering and find out for ya
stuarty
meany
posted on 26/3/11 at 09:47 PM Reply With Quote
possibly these????
ford Ka 93- 2008 (1.3)
scroll down to about half way, look for the casting number 48/20.
BCA2982 - 6542 , BCA2983 - 6542 at £74 each.
http://www.brakepartssuperstore.org.uk/contents/en-uk/d6542.html
meany
posted on 26/3/11 at 09:53 PM Reply With Quote
also google the 815
comes up with Ka passenger side in a couple of locations.
hootsno1
posted on 26/3/11 at 11:11 PM Reply With Quote
thanks guys i will try car spears shop if your right you get the GOLD STAR!!!
