mads
posted on 31/3/11 at 06:38 PM |
mounting steering column to chassis
sorry for all the questions...
how have people mounted their steering column to the chassis, just before the bulkhead. just wondering if there are brackets i can buy or do i need to
make some?
and anyone found that the column is very close to one of the rails therefore not allowing much movement of the column downwards (if needed)?
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in
sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
Davegtst
posted on 31/3/11 at 06:44 PM |
Yep the column is so close that i ditched the adjustable column and made it fixed. Does yours not have the brackets welded to the hoop? I used the
standard sierra adjustable bracket on the column and bolted it to this.
big-vee-twin
posted on 31/3/11 at 07:05 PM |
Heres a close up you can see the brackets
[Edited on 31/3/11 by big-vee-twin]
http://www.triangleltd.com
Davegtst
posted on 31/3/11 at 07:29 PM |
Here's a few of mine, you can just about see the bearing inside on the last picture.
mads
posted on 31/3/11 at 08:02 PM |
that's why your message didn't make sense.... i dont have the grey metal bracket with my column so couldnt work out how to mount it.
right, post in the wanted section next...
40inches
posted on 31/3/11 at 09:03 PM |
This any good? SIERRA SAPPHIRE COSWORTH ADJUSTABLE STEERING COLUMN on eBay (end time 02-Apr-11 19:23:56 BST)
dave-69isit
posted on 31/3/11 at 09:05 PM |
will u be at mondays meeting if so i might be able to help u
