zetechamo
posted on 5/4/11 at 04:24 PM |
spark plugs
Has any one got any idea what spark plugs to use in a Zetec Turbo engine. I am currently running standard NGK plugs but yesterday whilst on rolling
road the plugs melted. We were running about 1 bar of boost and had achieved 260bhp when we had to stop due to plugs. There was more to come from the
engine but could not contine due to plugs. So need to replace plugs with colder running plugs, but am not aware of any different plugs for Zetec
engine.
T66
posted on 5/4/11 at 04:35 PM |
surely its the combustion / egt that is causing the plugs to melt ?
Bare
posted on 5/4/11 at 04:45 PM |
Ermm.. you didn't mention what # your 'melted' NGK's were? Whatever.. you need colder ones (larger number) as a start
DynoJet?? That's usually How? one 'gets' 260 hp on a measly 1 bar boost.
There are issues in your setup it seems.
T66
posted on 5/4/11 at 05:34 PM |
My saab started life on bpr6 plugs and 200bhp , I briefly ran it at 280bhp with the 6s then swapped to its current bpr8s.
But never had any issues with the extra boost, egt heat etc on the 6s. When removed they were clean and looked fine. And it ran ok with a few more
knocks than I would of preferred, now on the 8s I dont get many.
Isnt the higher number of the plug the cooler it runs ? Ive used various setups in my car , some were lazy tunes with easy going boost, while others
lagged a bit then went absolutely mental , but Ive never got near as far as I know to melting plugs.
My alarm bells would be ringing now...
go easy
coyoteboy
posted on 5/4/11 at 05:57 PM |
Never seen plugs melt, must have been going some! Just be wary when going colder that idling becomes somewhat more sensitive to tune - running rich
will found the plugs pretty much instantly.
perksy
posted on 5/4/11 at 10:09 PM |
Think the Sierra Cosworth Turbo uses Grade 8's iirc
austin man
posted on 5/4/11 at 10:35 PM |
Dave Walker was doing the setup using an emerald ECU so I wouldnt question the setup
DRC INDY 7
posted on 6/4/11 at 08:21 PM |
I see what you mean austin man
Puddle Dodgers Club
jacko
posted on 6/4/11 at 08:37 PM |
I would have thought Dave would know what i best plugs to use did you ask him ?
