Author: Subject: Handbrake Levers
posted on 8/4/11 at 11:16 AM Reply With Quote
Handbrake Levers
Does anyone know of a handbrake lever that has it's mounting flanges vertical? Basically I want a lever just like the Rally Design one below, but without the 90 degree bent mounting flanges.
It's Evolution Baby!
Daddylonglegs
posted on 8/4/11 at 11:23 AM Reply With Quote
Can you not drill trough the sides of the brackets that are already there and maybe use a spacer on the front one to clear the lever?
Or tell me to shut up
Or even heat and straighten (carefully) the ones that are there already?
[Edited on 8/4/11 by Daddylonglegs]
posted on 8/4/11 at 11:24 AM Reply With Quote
Possibly... only problem with that is I wouldn't know for sure until I had the handbrake in my hand.
chrsgrain
posted on 8/4/11 at 11:28 AM Reply With Quote
Trigger handbrakes have one - here
Beautiful, but not cheap (good value though I think!)
Chris
Humbug
posted on 8/4/11 at 11:53 AM Reply With Quote
Or drill through and replace the bent brackets with straight ones - easy enough to make from flat bar/plate, I would think?
blakep82
posted on 8/4/11 at 12:05 PM Reply With Quote
angle iron type stuff, fit that to the exisitng brackets, and then that to wherever its going. not the prettiest, but easiest i'd say.
________________________
r1_pete
posted on 8/4/11 at 12:07 PM Reply With Quote
The one in your picture is almost identical to a MK3 Cortina unit, I remeber fitting one in a Consul Capri to replace the umberella handle type. I'd guess the MK4 is the same, but about as scarce.
Daddylonglegs
posted on 8/4/11 at 12:12 PM Reply With Quote
Aha! That would be an advantage I guess
BillHoll
posted on 8/4/11 at 01:19 PM Reply With Quote
Metro and MGF have vertical mountings, I am using the metro one in my build. It also has the switch for the telltale light.
big_wasa
posted on 8/4/11 at 02:49 PM Reply With Quote
METRO
theconrodkid
posted on 8/4/11 at 08:26 PM Reply With Quote
MG midget,all chrome and sexy like
who cares who wins
pass the pork pies
Marcus
posted on 12/4/11 at 10:26 AM Reply With Quote
Toyota MR2 gets my vote. Mine's out of s mk1, but I think mk2's are similar
Marcus
Because kits are for girls!!
Surrey Dave
posted on 6/7/11 at 01:24 PM Reply With Quote
MG Midget
[img][/img]
