Author: Subject: Headlight Height
Daddylonglegs
posted on 8/4/11 at 08:33 PM Reply With Quote
Headlight Height
I seem to recall someone on here had an IVA fail not too long ago and one of the issues was the height of the headlights. Apparently the tester said it obstructed the driver's view. I'm a little paranoid now that mine are too high, even though they are well within the limits set by the IA manual. Any views ('scuse the pun ):
Lights
Lights
Not the best angle but I can always take some more tomorrow.
JB
The Modfather
posted on 9/4/11 at 09:10 PM Reply With Quote
If they are within the height and width regs then leave alone, unless you want to change them. Cannot really see (excuse the pun!) what you are worried about. I do understand in regards to blocking the view, as our cars are low anyway, so that might be a cause to fail. Ring your local test centre and ask, might save you the worry and a fail!
Good luck
Daz
