dan8400
posted on 11/4/11 at 10:44 AM |
Intermittant ignition failure
Morning all,
Recently I've been enjoying the sun in the Tiger. It has developed a problem. Seems to loose ignition. Sometimes under acceleration/overtaking
sometimes when just tootling round town.
I can't put my finger on the problem. I loose all power (as if if I've turned the key off or something) If I flick the ignition key off
then on the exhaust "pops" and i'm back to full power.
I'm running 1.8 zetec on bike carbs and megajolt.
Don't think it's a dodgy ignition barrel (sierra) but I could be wrong. Key isn't loose or anything. Also, sometimes loose the
rev-counter (drops to zero) when driving then it comes back on sometimes it goes then I loose power/ignition
Dan
[Edited on 11/4/11 by dan8400]
Hey - That's Journey!!!
r1_pete
posted on 11/4/11 at 10:59 AM |
Is the rev counter powered from the MJ? if so it sounds as though you have loose connections or dry joints in the MJ or its connections, I would also
check the ignition switch connections are clean and tight.
It could be the switching off / on produces a spike which overcomes the poor connection.
RoadkillUK
posted on 11/4/11 at 11:35 AM |
This is interesting Dan, I have the same problem, it's not as bad as it used to be, it used to cut out on roundabouts (as well as randomly). We
changed the ignition barrel and it's much better, only does it now very infrequently and usually when cold.
I tested my theory by bypassing the ignition barrel by using 2 peices of wire, one for perm ignition and touching (like in the films ) for the
starter.
HTH
I'll keep an eye on this thread, see what happens.
Edited to say that we have the same setup, 1.8 Zetec, bike carbs and MJ.
[Edited on 11/4/11 by RoadkillUK]
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
MkIndy7
posted on 11/4/11 at 01:09 PM |
Is the rev counter powered from the Megajolt? Or completely separate?
Might be worth checking the proximity of the Crank Position sencor and the strength of it's mounting bracket, if it vibrates at certain
RPM's or conditions it could be loosing the signal. If it was a fault with the megajolt it would revert to limp home mode if it's still
using the EDIS module.
woolly
posted on 11/4/11 at 01:16 PM |
had similar twice now with MJ. but on a pinto
1st one was the wire breaking as it goes in to the housing of the crank sensor.
found by gently moving the wire whilst ticking over, then it would stutter or stop.
2nd turned out to be the distance of the sensor to the trigger wheel was to far away.
this was harder as it only happened at 2100 revs either side ok.
both cases just as if you had turned the key off and on. and the rev counter going to zero or fluctuating badly.
dan8400
posted on 11/4/11 at 03:06 PM |
The rev counter is powered from the MJ directly. Haven't sat down and checked anything yet. Thought I would see if anyone has had the same
trouble first
Dan
dan8400
posted on 11/4/11 at 03:11 PM |
Using EDIS module with Megajolt. Just to clarify
Also the crank sensor mounting is part of the engine block casting so hopefully that hasn't moved lol.
Dan
ditchlewis
posted on 11/4/11 at 07:14 PM |
I may be a long way off the track but had a similar problem on friday, it turned out to be the fuel pump.
are you running an mechanical or electrical fuel pump? once home i found the fault to be loose connection on the power supply to the pump, the engine
would die and stop. after cranking over a few times it would run again... well untill it stopped altogether on the busy duel carrageway.
it,s just a thought but it might help.
regards
ditch
RoadkillUK
posted on 11/4/11 at 09:31 PM |
If Dan's issue is the same as mine, the ignition needs to be switched off and then back on again. It won't start again without.
I've got it down to a fine art, ingition off - on, lift clutch, vroom vroom
Again, same setup as Dan, Edis and original sensor, original hole.
Roadkill - Lee
www.bradford7.co.uk
dan8400
posted on 12/4/11 at 06:19 AM |
I have an electric fuel pump. It keeps going all the time when stopped or started (obviously with the key on)
Sounds the same as your problem RoadkillUK
Dan
MkIndy7
posted on 12/4/11 at 09:09 AM |
I only ever had something similar happen once with the Megajolt and that was after a long haul up the M6, just coasted over to the Hard shoulder
switched it off and back on again for it never to happen again (can't rememeber if it would refuse to restart without switching off and back on
presume I'd have tried bumping it off while still coasting).
Never did find anything wrong with it, just presumed maybe a stone had jumped up between the sencor and the trigger wheel or something really
freak.
Could underbonnet Temps be playing any part? The EDIS is mounted to a solid metal to displace any heat from what I remember, have you done anything
similar? Or is there plenty of airflow over it.
dan8400
posted on 12/4/11 at 10:25 AM |
The EDIS is mounted flat on to aluminuim surface but is under the dash. Would turning it on/off kick it back into life if it's already hot? And
does it get hot?
Dan
gdp66
posted on 12/4/11 at 10:32 AM |
had a similar issue when first on the road.
I think it was due to earthing, so put an extra earth strap from the gearbox to the chassis.
