tony@signtek.net
posted on 11/4/11 at 05:59 PM |
r1 cylinder head needed!!
I,ve been turned over!!
After much head scratching i have discovered the cams on my 02 5pw are from an earlier carb version R1 and don't have the pickup for the cam
sensor
also the cam holders which are supposed to be mated to the head look like they have been scrounged from another engine and lock the inlet cam when
tightened
Altogether a total ballsup!!!
I need to source a complete 02 5pw head with cams
Hope someone can help a very pissed off carbuilder
Tony
Yazza54
posted on 11/4/11 at 08:05 PM |
I have a head I'm not using with cams, valves, cam fittings etc from a 5pw. The head is damaged from a bike that fell over but will the 5pw cams
and bit be of any use to get it going?
I'm unhappy cos I eat and I eat cos I'm unhappy
tony@signtek.net
posted on 12/4/11 at 10:41 PM |
Thankyou for the offer but i need a complete head as the camshaft clamps have to be mated to the head i think
How is the head damaged?
Regards
Tony
Yazza54
posted on 14/4/11 at 07:56 AM |
Shouldn't you be able to just fit 5pw cams for the pickup?
The 5jj and 5pw cams are the same apart from the pickup so I'd have thought they'd fit.. Someone else maybe able to confirm. The head is
cracked where the cam chain runs mate. Looks like the bike fell over and landed on the head bobbin.
