Author: Subject: Cutting Ti bolts
posted on 13/4/11 at 08:40 AM Reply With Quote
Cutting Ti bolts
Anybody has experience in cutting Titanium bolts?
I've bought some M5 and M6 Ti bolts and will need to shorten some of them so will a hacksaw do it or it is angle grinder/dremel cut off disc time?
Will a file or die be hard enough to reform the threads?
Phil.J
posted on 13/4/11 at 08:50 AM Reply With Quote
Use a sharp hacksaw blade and full strokes. The problem with working titanium is it work hardens so quickly, but with small bolts like that it should be OK.
liam.mccaffrey
posted on 13/4/11 at 09:11 AM Reply With Quote
I've never done it but was under the impression it was too hard to hacksaw. Surely a small cut off wheel would be way quicker?!
Build Blog
Build Photo Album
posted on 13/4/11 at 09:13 AM Reply With Quote
liam - that is what heard hence why I asked Anybody has experience
RickRick
posted on 13/4/11 at 09:23 AM Reply With Quote
hacksaws fairly easily with a fine blade, blades don't last that long though, teeth tend to fall off, and can be filed to clean threads up afterwards
liam.mccaffrey
posted on 13/4/11 at 09:45 AM Reply With Quote
Ooh, hush my mouth!!
Build Blog
Build Photo Album
Steve Hignett
posted on 13/4/11 at 09:52 AM Reply With Quote
Yeah Liam, it's not as if you're 20 years of international engineering experience and studies will allow you to have any clue or offer any helpful advice, you complete arrogant person. How dare you...
907
posted on 13/4/11 at 10:12 AM Reply With Quote
It will cut with a hacksaw no prob, and turns on a lathe with a really good finish.
Doesn't like grinding or cutting discs as these heat the edge and form Ti oxide.
This compound is hard, if fact some sanding discs are made from this.
Paul G
p.s.
Ti swarf if coated with cutting oil or WD40 makes a spectacular display in a pub ash tray when ignited.
p.p.s.
I probably shouldn't have said that.
p.p.p.s.
It's OK. No pub ash trays anymore.
liam.mccaffrey
posted on 13/4/11 at 10:20 AM Reply With Quote
Crap Steve dude how old do you think I am , as Paul pointed out though I clearly have very little experience working with Ti and should have kept quiet perhaps.
[Edited on 13/4/11 by liam.mccaffrey]
Build Blog
Build Photo Album
907
posted on 13/4/11 at 10:30 AM Reply With Quote
I hope I haven't offended you Liam.
Very sorry if I have. Not my intention at all.
Paul G
andrew-theasby
posted on 13/4/11 at 11:18 AM Reply With Quote
be careful if grinding cause even the sparks can set the filings on fire if you get a build up!
onenastyviper
posted on 13/4/11 at 12:02 PM Reply With Quote
Interesting Factoid: Titanium can burn in Nitrogen.
