nib1980
posted on 17/4/11 at 02:01 PM |
How bleed wilwood brakes?
Hi
Anyone got any tips for bleeding 4 pot wilwood callipers?
I just can't seem to get a good solid feel to the pedal.
Many thanks
Neil
adithorp
posted on 17/4/11 at 03:41 PM |
I opened the bleeders and let them gravity bleed first, shutting the nipples as fluid came through. Then I just bled them one at a time in the normal
manual way, starting with the closest to the master and working around to the furthest. On each caliper I did the inner nipple first then the outer
and then re-checked the inner.
If you've got twin masters/balance bar you might have to do one front and one rear together as the balance bar can lock and prevent full
movement on just one cylinder.
http://jpsc.org.uk/forum/
nib1980
posted on 17/4/11 at 06:17 PM |
thanks i'll have another go.
any one got any other tips?
nib1980
posted on 17/4/11 at 06:54 PM |
mental note to self.
BLEED BOTH SIDE OF THE CALLIPER
i feel such a dumb ass!
adithorp
posted on 17/4/11 at 07:28 PM |
Good pedal now? Don't worry, we've all missed something "obvious" befroe.
