Benzine
posted on 15/7/04 at 04:05 PM |
Rear hubs & track rod end
More n00b questions
How far in does this have to go? It seems v.tight and starts to grate against the hub, should it do that?
When i try to undo the nuts on the track rod ends the bolts moves with it, how can i get them off :S (no room for mole grips access )
Thanks for any help
[Edited on 15/7/04 by Benzine]
The mental gymnastics a landlord will employ to justify immoral actions is clinically fascinating. Just because something is legal doesn't make
it moral.
PAUL FISHER
posted on 15/7/04 at 04:34 PM |
with that type of shaft you will need to lathe it off ,its not required as its the ABS ring on the sierra.
the track rod nut can be remove by putting a bar between the bottom of the track rod and lower wish bone and apply upward pressure,at the same time as
turning the nut.
cheers PAUL
Dusty
posted on 15/7/04 at 04:35 PM |
Can sometimes get the trackrod tapers to jam by jacking under the joint to force it further in, then undo the nut.
shortie
posted on 15/7/04 at 04:39 PM |
Hi Benzine,
Just to let you know I haven't forgotten about sending your CV joint, just been a bit busy this week as we've had a gas leak at home!!
Looking at you pic it looks like you have the same problem I did, the teeth on the drive shaft need to be removed (most people get it done by someone
with a lathe) or you can make the hole in the hub bigger which is what I did in the end using a dremel for speed but you can do it by hand, just takes
longer! The teeth are for the ABS system in the 4x4 sierra, non 4x4's (standard donor) don't have them so MK make the hub to fit the
standard.
It's a pain but didn't take long with the dremel, if you've got a lathe it would be even quicker to remove the teeth.
As for the track rod ends I reckon it's worth getting some new ones, I used new ones and had no problem.
Hope that helps,
Rich.
Benzine
posted on 15/7/04 at 05:04 PM |
Thanks all round
it moral.
James
posted on 18/7/04 at 08:13 PM |
Benzine,
I'm gonna sound like a Dad now (which I'm not thank god!)...
Don't take this the wrong way- I personally don't mind what language I see/hear but I think some people on this forum will get upset at
what's written on your signature- mainly because some read this forum with their kids!
Sorry to sound like I'm nagging!
All the best,
James
![](/images//smilies/bigsmile.gif)
adam_moore
posted on 19/7/04 at 11:35 AM |
On the subject of rear bearings...I re-assembled the first on my rear (disc) hubs OK after filing of the ABS sensor ring but the bearings are really
tight...so much so that its hard to turn the driver flange...
Has anyone else had this problem? Fingers crossed I haven't got the bearing races mixed up...!
Benzine
posted on 19/7/04 at 11:23 PM |
quote: Originally posted by James
Benzine,
All the best,
James
What are you talking about? :S
it moral.
