Author: Subject: Tyre pressures
j3w3ll3r
posted on 26/4/11 at 11:53 AM Reply With Quote
Tyre pressures
Hiya
What is the ideal tyre pressure for
15" toyo r888 for road and then for track
Stephen
www.essexhomegame.co.uk
shaun fulcrum
posted on 26/4/11 at 12:13 PM Reply With Quote
Might be wrong but, 21 psi when hot for both is what I use and seems perfect
Correct me if I'm wrong.
j3w3ll3r
posted on 26/4/11 at 12:33 PM Reply With Quote
Just been in the tyre shop to get the tracking done and they've said that we had 15psi in them which seems very low, so they pushed them up to 29psi (on recommendation)..
I think that seems a little steep.. ?
Any advice greatly appreciated.
Thanks.
whitestu
posted on 26/4/11 at 12:35 PM Reply With Quote
15 psi cold will be more like 18 hot. 29 is too high.
Madinventions
posted on 26/4/11 at 01:06 PM Reply With Quote
My car weighs 523kg and I run 16psi from cold for road use. Not enough track experience to say what track pressures should be.
29psi is ok for a 1500kg+ tin top, but way too high for cars as light as ours!
View my band website:
http://www.shadowlight.org.uk
Frosty
posted on 26/4/11 at 08:13 PM Reply With Quote
No such thing as ideal - only ideal for your specific car and tyres.
Start with 18PSI cold and adjust accordingly.
If your tyres have soft sidewalls, you might want to add a couple of PSI. If they are very stiff you might want to remove a couple instead.
Ignore what the tyre shop tell you - they just bang in 30psi without understanding what that really 30psi does. It's just an accepted ballpark figure for a road car - but not for a kit car
Windscreen Wipers
Need windscreen wipers for your car? Order from a friendly kit car owner.
Don't pay a garage to do them. You built a car for God's sake - I'm sure you can fit your own wipers!
