Martin1989
posted on 27/4/11 at 06:34 PM |
TB's with Bogg Bros manifold - Zetec
Have changed my mind on what I'm doing with the Tiger again and have decided to go for 45's instead of injection (anyone have any for
sale?)
Below are some pictures and this is what is included:
- Bogg Bros manifold to take bike throttle bodies and be fitted to a Zetec
- ZXR 45mm throttle bodies
- Throttle position sensor
- Throttle linkage
- Fuel rail
- Injectors
- Fuel pressure regulator
- Air filters
- All the stuff to make them fit together
Looking for around £370. Any question please U2U and don't hesitate to ask.
Now for the pictures:
![](http://img692.imageshack.us/img692/8038/93284467.jpg)
speedstar
posted on 27/4/11 at 06:39 PM |
If you ever decide to split this i'd be very interested in the manifold!!
You don't happen to have an ECU going as well would you?
Martin1989
posted on 27/4/11 at 06:40 PM |
I'll see if I can sell it all together and would prefer to sell it this way. As for the ECU already gone sorry.
lewis
posted on 27/4/11 at 06:51 PM |
I have twin weber 45s on my pinto and will be going with the setup you have there when I change to my blacktop so they will be up for grabs maybe do a
deal? I obviously have a pinto manifold not zetec.
austin man
posted on 27/4/11 at 07:03 PM |
have a set of 40's on a zetec manifold with all linkages if any good
big_wasa
posted on 27/4/11 at 08:59 PM |
Hmm having had webers I couldnt wait to get rid and go injection.
Mine where the proper zetec spec 152g five progresion hole dcoe 45's.
Norfolkluegojnr
posted on 28/4/11 at 12:43 PM |
Fighting the urge........
Just out of interest, what else (excluding Omex/MS) would i need to get these running on my carbed Zetec?
![](/images//smilies/smile.gif)
Martin1989
posted on 28/4/11 at 12:51 PM |
High pressure fuel pump (maybe 2 but can use a normal low pressure fuel pump for the fuel to go back to the tank), wiring loom for the ecu, air and
water temp sensors, cat and you may also need a lambda sensor.
Martin1989
posted on 30/4/11 at 02:58 PM |
Price drop to £350.
Martin1989
posted on 13/6/11 at 06:23 PM |
Will let these go for £300 now.
shindha
posted on 13/6/11 at 08:16 PM |
U2U sent
