Mr Whippy
| posted on 28/4/11 at 09:26 AM |
Another trailer weight question
Hi
A friend is wanting to borrow my double axle braked flatbed trailer but only has a licence to tow a trailer up to 750kg, their only wanting to move
some fence panels but they are very light but bulky.
If I disconnect the brake link in mine making it effectively an unbraked trailer would that then allow them to use it, so long as they don't get
the trailer all up weight over the 750kg mark?? I guess the trailer must be about 300kg empty.
God I hate all these new laws
thanks.
cloudy
| posted on 28/4/11 at 09:32 AM |
Not sure where this braked/unbraked law is?
The short rule on DVLA is:
Car licences obtained on or after 1 January 1997
If you passed a car test on or after 1 January 1997 you're limited to vehicles up to 3.5 tonnes maximum authorised mass towing a trailer up to
750kgs, or a vehicle and trailer combination up to 3.5 tonnes MAM providing the MAM of the trailer doesn't exceed the unladen mass of the towing
vehicle. You will need to pass an additional driving test in B+E if you wish to tow a caravan or trailer combination which exceeds these weight
limits.
So you can in fact tow more than 750kg as long as it's MAM doesn't exceed the unladen mass of tow car... It doesn't mention braked
trailers being an issue?
www.warnercars.com
Norfolkluegojnr
| posted on 28/4/11 at 09:44 AM |
As above - but any trailer + load above 750kgs needs to be braked.
Let him borrow it, leave the brakes and he should be fine. What i do is print of the paragraph from the direct gov site, and keep it in the car with
me. If any plod takes issue, I'll get the print out and show them.
Not happened yet though. If the load looks safe, and you aren't braking speed limits etc, you're unlikely to get pulled anyway.
Mr Whippy
| posted on 28/4/11 at 09:45 AM |
hmm well this is my thinking on the MAM of the trailer, as above 750kg you need a braked trailer meaning that any trailer that is braked naturally
must have a MAM (i.e. maximum carrying capacity) of over the 750kg hence my thinking of just disconnecting the brakes...
It's this MAM that seems to be the problem that they now go by what a trailer is capable of carrying and not what it is carrying which is why
folk are getting done just towing empty trailers!
Norfolkluegojnr
| posted on 28/4/11 at 09:53 AM |
I believe (not 100% sure) that having brakes that are ineffective on a trailer is an offence, so probably not a good idea. i.e. if you have brakes,
they have to be working.
If the trailer MAM is over 750kg leave the brakes as is. He'll be fine as long as he meets the vehicle MAM requirement.
Mr Whippy
| posted on 28/4/11 at 10:00 AM |
ok will leave the brakes working, there is no plate on the trailer stating what it can carry, just the hitch has some weight ranges but that's
an after market thing.
cheers
cloudy
| posted on 28/4/11 at 10:38 AM |
Suggest making a plate to show the MAM specification... Just make sure it's correct
www.warnercars.com
Richard Quinn
| posted on 28/4/11 at 11:26 AM |
Yup, a lad who worked for me was done towing an empty plastic tank (weight = 4/5 FA) on a trailer plated for 3500kg. Van and trailer were impounded by
the police at a VOSA weighbridge. He got £60 and 3 points and someone else had to go and collect the van/trailer. Don't know how you would stand
on a non-plated trailer.
Mr Whippy
| posted on 28/4/11 at 11:32 AM |
It's a bit much tbh as I have never heard of the changes on the telly and only found out by chance on here. No one else I have spoken to about
it has ever came across MAM weight's
| posted on 28/4/11 at 12:16 PM |
there has to be some proceedure for the police or vosa to follow in the case of unplated trailers. They cannot just accept your word about what its
rated at. I have 3 unplated trailers, so could use knowing!
StrikerChris
| posted on 28/4/11 at 12:28 PM |
Its not as simple as your just limited to 750kg's.I belive (but don't quote me) that you can tow more than 750kgs on a new license as long
as the total train weight is less than 3 or 3.5 tonnes.
Chris
Mr Whippy
| posted on 28/4/11 at 12:37 PM |
I don't think there is any requirement to fit weight plates to a trailer. I have a 1 year old one (the double axle in the posts above) that I
bought new (picked it up from the manufacturer) and it has no plate on it.
As I said earlier I think it is just the combination of axle load rating, brake rating and tow hitch rating that gives the trailer it classification
for towing. Exceed any of these with a load and you not conforming to the law.
I posted an earlier question about a new trailer I was wanting to build for carrying model planes to be towed behind my Falcon but was going to be a
huge box one but unbraked due to it carrying only about 100kg of models. I could see me getting pulled over all the time especially as I wanted 3
axles so it rolled very smoothly. So what would the trailer be rated for, ehem well with unbraked axles even though it would be huge then just 750kg,
fine.
Dangle_kt
| posted on 28/4/11 at 12:52 PM |
I had an unplated trailer, and was under the impression (though cant find the link) that in cases of doubt they have to take you to a VOSA station
weighbridge to check. If they can be bothered.
Personally I'd drill the plate off and rivet it back on when he drops it back off - it'll take a few seconds.
The tow car comes into play too with all the MAM stuff. With my car I could tow anything up to 1200kg with my car and not go over the limit for my
licence. My locost is 476kgs and the trailer is FAR less than 700kgs so I knew I was golden. But if I was driving a defender I couldnt tow anything
cos it has a 3500kg MAM on its own!
