Author: Subject: Escort Mexico rack
Northy
posted on 17/7/04 at 12:56 PM Reply With Quote
Escort Mexico rack
Does anyone know what differences there are between a std mk2 Escort rack and an Escort Mexico rack?
Are the fixing points the same? Is it "quicker"? And most important, are the track rods longer?
Graham
cosworth
posted on 17/7/04 at 05:24 PM Reply With Quote
Its exactly the same if its a std rack the only difference is that it uses green RS track rod ends
Northy
posted on 17/7/04 at 06:37 PM Reply With Quote
Whats the difference with the green track rod ends? Are they longer?
Graham
Tblue
posted on 17/7/04 at 11:34 PM Reply With Quote
No, but I'm presuming that you want them to be?
Northy
posted on 18/7/04 at 08:03 AM Reply With Quote
Yes, I need more length!
Either the track rods, or the track rod ends, I'm not too bothered. A friend suggested group 4 track rod ends, but I can't find them anywhere
Any ideas welcome.
Graham
Tblue
posted on 18/7/04 at 10:32 AM Reply With Quote
You could try using a Capri or Mk3, 4 or 5 rack as these are wider, or just extend the track rods by cutting them and using a decent wall thickness sleeve. Be sure that your welding is up to it though.
type 907
posted on 18/7/04 at 12:28 PM Reply With Quote
Hi Northy,
Have a look in my photo archive at wishbone assy or rack ext.
Is that what you need?
Paul G
Too much is just enough
Northy
posted on 18/7/04 at 07:08 PM Reply With Quote
Type 907, I thought about doing it like that but here's my problem.
At the moment, with the wheels set to zero toe, there is nearly enough threads into the track rod ends, but would prefer a bit more. I'd like a little toe out for SVA, which would be a little risky. If I put extensions on, I'd have to cut down the track rods, and would be back to not enough threads into the extension (I think). Just had a thought though, I could cut a bit off the track rods aswell.
All suggestions welcome fellas, this ones worrying me a bit, I don't want it to dive off into a hedge one day!
BTW, I didn't think you could extend and weld steering components, thought it was an SVA fail.
[Edited on 18/7/04 by Northy]
Graham
Viper
posted on 18/7/04 at 07:27 PM Reply With Quote
Any signs of the track rod having been welded is an mot failure and as such i don't think Mr SVA would be impressed.
cosworth
posted on 18/7/04 at 08:08 PM Reply With Quote
I think the length of green TRE's is the same it is the taper that is different
