Author: Subject: English axle prop to diff bolt size?
house19uk
posted on 9/5/11 at 07:06 AM Reply With Quote
As above can someone tell me what the bolt size and strength is for connectingthe prop to an English axle?
Dopdog
posted on 9/5/11 at 07:50 AM Reply With Quote
here you go
Atlas/English Axle Prop Shaft Bolt Escort MK1 MK2 Capri | eBay UK
MK9R
posted on 9/5/11 at 08:09 AM Reply With Quote
They are also the same as the prop to viscous coupling bolts on freelander 1's, you can buy them your local LR dealer
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
posted on 9/5/11 at 08:59 AM Reply With Quote
Two completely different designs of flange were used on english axles with completely different bolts.
Early ones with the smaller flange were plain 5/16" UNF bolts.
