gavin174
posted on 9/5/11 at 05:03 PM |
manual or auto blacktop
Hi all
does anyone know if the 2.0 zetec (blacktop) auto is the same engine as the manual...
or is it lower compression
cheers Gavin
doddy
posted on 9/5/11 at 05:13 PM |
i think the flywheel is differnt you will need a maunal one
https://www.ebay.co.uk/str/4x4wheels
gavin174
posted on 9/5/11 at 05:15 PM |
of course.. didnt think of that..
torque converter and all..
but what about engine internals..
big_wasa
posted on 9/5/11 at 05:19 PM |
As far as I know internals are all the same, ecu map is the differance. The Crank Position Sensor Housing is differant and will need swaping over.
gavin174
posted on 9/5/11 at 06:35 PM |
anyone have a spare Crank Position Sensor Housing?
would this be what I need
FORD MONDEO MK3 PETROL CRANKSHAFT CRANK POSITION SENSOR | eBay UK
[Edited on 9/5/11 by gavin174]
big_wasa
posted on 9/5/11 at 06:43 PM |
No thats a duratec sensor. Its the housing thats differant on the zetec.
gavin174
posted on 9/5/11 at 06:46 PM |
thanks for the fast replies...
will have to check if there still available from ford then.
L5W
posted on 9/5/11 at 08:15 PM |
I have the housing from a silvertop which you're welcome to. I'm not sure if its the same as the blacktop one though.
Lee
http://l5w-mk-indy-zetec.blogspot.com/
gavin174
posted on 9/5/11 at 08:19 PM |
I think the part no. I am after is 928F-6K341-AF
http://locostbuilders.co.uk/forum/9/viewthread.php?tid=140115
mcerd1
posted on 9/5/11 at 08:20 PM |
I wouldn't bother with ford, its bound be out of stock and cost a fortune
even if L5W's ones no good there should be loads of manual blacktops in the scrapyards and I can't see them charging much for one of
them
(ps - do you fancy pick up a speed sensor for my focus while your there )
[Edited on 9/5/2011 by mcerd1]
big_wasa
posted on 9/5/11 at 08:39 PM |
Its only one bolt to remove it BUT thats after you have removed the gearbox and flywheel.
