Author: Subject: sierra diff tool wanted please
andrew-theasby
posted on 9/5/11 at 05:28 PM Reply With Quote
Hi, does anyone have the tool for undoing the castleated lock rings on the output bearings on a 7" sierra diff, before i buy one, that i could buy or borrow please?
Sierra/Scorpio Diff bearing tool. Ford/Kitcar/Caterham | eBay UK
mookaloid
posted on 9/5/11 at 05:34 PM Reply With Quote
Ooh you're posh - I just use a bit of flat bar of suitable size held across the diameter and it gives enough purchase to undo the ring.
gavin174
posted on 9/5/11 at 05:54 PM Reply With Quote
i have seen a very clever person use an old brake disc,
with 6mm bolts through it, in strategic places..
then turn the disc like a steering wheel
hope this makes sense.
if not will try and get some pics...
andrew-theasby
posted on 9/5/11 at 06:02 PM Reply With Quote
Just realised do i even need to undo these to remove the otput flanges, or are they circliped in (or similar) from the inside?
gavin174
posted on 9/5/11 at 06:13 PM Reply With Quote
on the bolt on shafts you need to remove the rear cover and there is a circlip on the inside..
andrew-theasby
posted on 9/5/11 at 06:24 PM Reply With Quote
ok thanks, cancel that then, i dont need one now
