littlefeller
posted on 9/5/11 at 08:51 PM |
fwd donor
does anyone know of a way of using a fwd transverse engine for rwd, keeping in mind if i turn the engine through 90 degrees it is running backwards,
is it possible to just flip the diff?
blakep82
posted on 9/5/11 at 08:56 PM |
get a rwd gearbox that fits! thats how we all do it
how many ford zetecs or duratecs were rwd? none i think. i don't think ford do any rwd cars now, yet theres plenty of zetecs and duratecs in
peoples cars here
or am i missing something?
[Edited on 9/5/11 by blakep82]
________________________
littlefeller
posted on 9/5/11 at 08:59 PM |
but i think maybe the zetecs crank runs in the oposite direction
blakep82
posted on 9/5/11 at 09:02 PM |
nope. all engines run the same way, except some Jap angines. honda s2000 i think? vauxhalls, fords etc, all go the same way. i've got a vauxhall
enigne with a sierra gearbox, and capri back axle, and its all good
Bare
posted on 9/5/11 at 09:03 PM |
Most all current engines rotate the same direction these days.. Even Honda's :-)
[Edited on 9/5/11 by Bare]
littlefeller
thats exactly it, honda vtec engine but could i just run the dif upside down
wylliezx9r
posted on 9/5/11 at 09:04 PM |
Certain engines do run in the wrong direction, civic type r for one. But zetecs dont', simply turn it 90, mate it up to a rwd box and away to
go, well of course its not quite as simple as that lol
George Best
mcerd1
there is an answer for any fwd donor - build a car with a mid-rear layout, then all you need to do is move the whole thing to the back without turning
it
[Edited on 9/5/2011 by mcerd1]
littlefeller
posted on 9/5/11 at 09:06 PM |
change engine from transverse, or is there another way i hadnt thought off
blakep82
posted on 9/5/11 at 09:07 PM |
ah, right, didn't know you were using a honda engine lol. what about a s2000 diff? that would work the right way for you
not sure turning say a sierra diff upside down is ideal. might work. would need a few mods (blocking breather, and making a new one. got a feeling the
diff effectively running in reverse all the time (the input flange will be running the wrong way than it was designed to) it will wear out pretty
quick...
think a rwd honda diff is the best way
austin man
posted on 9/5/11 at 09:08 PM |
My Zetec certainly runs the correct way as does the S2000 and most others Im sure its only the type r which is a problem hence it being fitted in the
rear of the Atom so no problem with rotation
mcerd1
I think the S2000 engine turns the right way (unlike most honda ones) it designed for rwd and its still a vtec
littlefeller
posted on 9/5/11 at 09:10 PM |
i do like the whole engine backwards idea saving a shed load of work, been thinking along these lines originally. just wondering if anyone else had
used a honda h22a engine in rwd layout
mcerd1
posted on 9/5/11 at 09:12 PM |
quote: Originally posted by littlefeller
just wondering if anyone else had used a honda h22a engine in rwd layout
yes, but as far as I know only in a midi with its own box
think of something like a car engined version of the new MK midi
or as far as existing kits go both the GTM Libra and marlin 5exi use honda fwd as donors...
Dusty
posted on 9/5/11 at 10:14 PM |
You could always put the honda engine in the back, turned round, fit a prop to the front and use a sierra diff which would give front wheel drive but
in the right direction.
littlefeller
posted on 10/5/11 at 05:27 PM |
its an intresting problem, supose if i build as mid i could use the existing box and drive shaftes
mcerd1
posted on 11/5/11 at 10:32 AM |
^^ lots of reading to do in the midi section on this site
here's a few to get started with...
http://www.locostbuilders.co.uk/forum/26/viewthread.php?tid=133598
http://www.locostbuilders.co.uk/forum/26/viewthread.php?tid=82510
http://www.locostbuilders.co.uk/photos.php?action=gal&user=hughpinder&folder=hughpinder
adithorp
posted on 11/5/11 at 11:26 AM |
http://jpsc.org.uk/forum/
posted on 11/5/11 at 12:13 PM |
Easiest way to tell if it will run the right way for rwd is to open the bonnet... if the gearbox is down on the right (most fwd cars) it goes the
right way, if the gearbox is on the left (drivers side) it runs anticlockwise aka Rover 416.
All Ford engines run the right way and bolt up to a type 9. Apart from the Duratec which came from some where else....
Madinventions
posted on 11/5/11 at 12:45 PM |
Build a midi. Have a look at my build pages below which are for my Mojo build. This takes the complete engine/gearbox solution from a FWD and
puts it at the back. Simple, and good weight distribution too.
Ed.
View my band website:
http://www.shadowlight.org.uk
Madinventions
posted on 11/5/11 at 12:46 PM |
littlefeller
posted on 11/5/11 at 06:11 PM |
found a site in usa bout a guy building a lowcost style mid, this is what got me thinking of using my honda vtec engine, looked real cool. but this
left me with a couple of problems, i was originally thinking of buying an older - sva'd kit and modifying it to take the engine. didnt realy
want the complete build option. the second problem is i cant shake the image of that american build out of my head. and now just to make it worse,
ive seen yours
[Edited on 11/5/11 by littlefeller]
littlefeller
posted on 11/5/11 at 06:23 PM |
quote: Originally posted by Madinventions
hope you dont mind, just knicked some of your chasis pics.
Thinking about it
posted on 11/5/11 at 06:27 PM |
How that then Caterham use the 1.6 K Series. Im lost
posted on 11/5/11 at 06:35 PM |
Thing about midies is if the rear suspension is from a fwd donor it takes a great deal of attention detail to design out bump steer & roll
steer.
Anything that will mate to a Rover PG gearbox is easy to convert to mid installation as Rover MGF & MG TF bits will adapt the gear change, the
other simple way is choose an automatic donor.
