Author: Subject: mk front springs
brookie
posted on 12/5/11 at 07:40 PM Reply With Quote
mk front springs
right my mk blade has 250lb 9inch on the front and i can not get the correct rake on my car so looking to change them but what springs do i change them for, and the shoks are protech any help would be good
ReMan
posted on 12/5/11 at 09:36 PM Reply With Quote
250 is not far off.
200-225 are oftem used for becs
explain more about the correct rake that you cant get?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
austin man
posted on 12/5/11 at 09:45 PM Reply With Quote
it mab be the length that is the problem rather than the poundage I would suggest shorter springs
Frosty
posted on 13/5/11 at 12:36 PM Reply With Quote
9" does sound very long to me. Dropping to 8 should do the trick.
Windscreen Wipers
Need windscreen wipers for your car? Order from a friendly kit car owner.
Don't pay a garage to do them. You built a car for God's sake - I'm sure you can fit your own wipers!
brookie
posted on 13/5/11 at 04:32 PM Reply With Quote
so 8 would sort it then
phelpsa
posted on 13/5/11 at 05:05 PM Reply With Quote
Well that would depend on what the issue is in the first place!? What do you mean by 'correct rake'? Correct front ride height? Is that because the spring pan has reached the bottom of the thread? If so then yes it will help.
brookie
posted on 13/5/11 at 05:14 PM Reply With Quote
yes m8 that the problem im i right in say there has to be a rake of 15mm from front to back of the car ride hight or am i being told a load off bull
