Antnicuk
posted on 16/5/11 at 09:02 PM |
Why is the Centre of the Diff nose on an Atlas Off set?
Been looking at getting my atlas diff and my gearbox a bit better aligned in attempt to address the vibration i have and noticed that the diff nose if
off set from the centre by about 2-3 inches and just wondered why? Was the original ford engine/gearbox set up not in the middle of the car? i cant
think why else the diff wouldnt be in the centre?
Does it matter if i have the diff and gearbox offset both vertically and horizontally if the angles at each end both match?
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
deltron63
posted on 16/5/11 at 09:16 PM |
So the uj's can work properly
blakep82
think its just because the half shafts are equal length, which means the crown wheel is slightly off to one side, and so the pinion is off to the
other?
since the crown and pinion are individual items (there's only one of each in the axle) maybe it makes it cheaper to make all half shafts the
same? i guess its more expensive to make them different lengths.
i understand you shouldn't really have a prop perfectly in line as it has asome bad effect on the UJ bearings (so i've heard) maybe it
also ensures the prop is never perfectly in line and perhaps the bearings last longer if thats the case
________________________
ashg
posted on 17/5/11 at 07:38 AM |
nope all wrong they did it to reduce noise
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
adithorp
posted on 17/5/11 at 08:20 AM |
Yep, it's a hypoid gear and they're offset in order to be quieter. There's an explanation in CompleteKit Car mag a couple of issues
ago.
The Prop flanges should idealy be offset but the centre lines parrallel. This means the needle roller bearings in the UJ's move, so don't
wear as quick as they would if continually sat loaded in the same position. The flanges/centre lines have to be parrale lto cancel out the movement in
each other. Have a look at BaileyMorris site for an explanation.
http://jpsc.org.uk/forum/
Antnicuk
posted on 17/5/11 at 04:46 PM |
thanks chaps, very helpful
posted on 18/5/11 at 08:18 AM |
ago.
A hypoid gear will have the pinion set below (or above) the centerline of the crown wheel. I was under the (possibly incorrect) impression that
Antnicuk was wondering why the pinion isn't centred between the wheels, rather than top and bottom of the axle?
