blakep82
posted on 17/5/11 at 08:47 PM |
cutting tubes at angles
i know theres the tube 'mitreing' (mitring?) software showing you how to cut round tubes to fit the end of one into the side of the other
(not REALLY what i'd call mitring)
is there any to help cut a tube at 45 degrees at the end? to fit two tubes cut at 45 degrees together end on end to make a 90 degree corner?
can't seem to find one
just tried with a 45 degree square thing, it was becoming a cork screw...
________________________
Killer
posted on 17/5/11 at 08:53 PM |
Wouldn't a normal mitre box do it? Isnt it just a straight cut at 45 degrees then??
Rich
http://www.kilmartin.it/cgi-bin/gallery
blakep82
posted on 17/5/11 at 08:55 PM |
yeah, just a straight cut at 45 degrees, with a angle grinder. haven't got a mitre box, don't fancy buying any more tools just now, but
need an easy way to mark the cutting line all the way around the tube
RichardK
posted on 17/5/11 at 09:00 PM |
Shame you're not closer as you could have borrowed my chop saw
Gallery updated 11/01/2011
mark chandler
posted on 17/5/11 at 09:30 PM |
Mitre box is just a 3 off cuts off wood!
dhutch
posted on 17/5/11 at 09:37 PM |
Only software ive seen is for if you cutting a mitre on a round tube meeting another round tube by hand.
matt_claydon
posted on 17/5/11 at 09:55 PM |
Use the generic tube mitring software, put 45 deg as the joint angle and infinity (or as close as you can get) as the dia of the tube you are joining
to. This will give you a paper template for a straight 45 deg mitre.
I can't visualise what you'll get, but i suspect it'll be a sine curve or similar.
907
posted on 17/5/11 at 10:29 PM |
A plank of wood and 4 nails. Real Locost
I've been racking my brain cell and this is what I've come up with.
With your square mark a 45deg across a plank of wood.
With a rule mark a line parallel to the edge.
Knock 4 big nails a little way into the wood on the marked lines, nice and straight. (see pic)
To use G clamp the pipe to the wood against parallel nails and use the 45deg nails as a guide for a hacksaw.
Unlike the slot in a wooden mitre block the hack saw blade will run against the nails without wearing out.
If you wish when you have cut one (and got it perfect) you can wrap a sheet of paper round the pipe overlapping
the cut end and secure with tape. With a small hammer gently tap the cut edge under the paper and work round the cut.
This will cut the paper and give you a perfect paper template that you can photo copy and use.
Hope this helps.
Paul G
![](/galpreviews/mitre jig.jpg) ![Description](/gallery/mitre jig.jpg) Description
Steve Hignett
posted on 17/5/11 at 10:45 PM |
Just use a file instead of the hammer Paul, and it will "cut" the paper against the cut edge of the steel... (obviously, holding the paper
tight against the steel tube with your free hand!)
907
posted on 17/5/11 at 11:02 PM |
Unfortunately Steve I sold my file to help finance the purchase of a 9" grinder. ![](/images//smilies/wink.gif)
Steve Hignett
posted on 17/5/11 at 11:06 PM |
Get yourself down the market/pound-shop, they'd last at least a couple of go's on paper ![](/images//smilies/wink.gif)
blakep82
posted on 18/5/11 at 09:00 PM |
ha, 907 hit the nail on the head there!
nope, not block of wood and nails. 9" grinder! lol
my problems were mostly coming from having to make a cut with the grinder, turning it all round and cutting the other side.
got a cutting disc for my 9" grinder (only used it for stone/concrete cutting so far) and made 1 cut. much easier.
thanks for all the suggestions though!
mistergrumpy
posted on 18/5/11 at 09:18 PM |
Angry grinding at 2200 hours? Some people are trying to sleep here!![](/images//smilies/wink.gif) ![](/images//smilies/bigsmile.gif)
blakep82
posted on 18/5/11 at 09:26 PM |
you could here it in lancashire?! nah, i did the cutting at about 4pm, just gone out and welded it up.
