laurencedawson
posted on 19/5/11 at 10:20 AM |
body roll
Hi all,
I recently did a track day, apart from engine issues one of the problems we found was body roll-
looking at photos afterwards we seem to have a lot of body roll much more so than the various caterhams westfields etc...
even had some wear on the tyre wall from the wheel arch! for info we had the shocks set to full stiff
anyone experienced this? im almost thinking we will need to fit stiffer springs, currently have the ones supplied by tiger
thanks
les
posted on 19/5/11 at 11:09 AM |
You have to see the problem as two different and separate issues, the body contacting tyres indicates the bump stops need lengthened by add
extra rubbers, the excessive roll indicates you need extra roll stiffness either by increasing spring stiffness or the use of a anti-roll bar(s).
First step is to find out the spring rates and free lengths that are currently fitted and decide if the car handling balance is under-steer or
over-steer or is neutral
posted on 19/5/11 at 11:20 AM |
If you haven't already, check your tyre wear for camber. It could be that you need more camber, which may also cure the issue of your arch
rubbing. If the camber is fine, remove some of the fibreglass on the return lip of the wheel arch.
We had a similar issue with our Indy a few years ago with too much body roll on the rear. We played around with front and rear spring rates and
eventually found a combination that prevented excessive roll.
Also, what springs do you have?
Phil
posted on 19/5/11 at 11:33 AM |
One other thing having the shocks set to too stiff is not a good idea, you need to a dampers set quite soft or you are likely to suffer an unplanned
trip into the barrier.
If you set the dampers too stiff the wheel will skip over undulations in the road causing sudden loss of grip ie the car will feel great but
without warning spin out in the blink of an eye.
laptoprob
posted on 19/5/11 at 11:34 AM |
Oh the joys of Tiger Avon handling......
I had exactly the same problem with my C20XE Avon.
[img] [/img]
[img] [/img]
The cars actually handle ok to a degree but on track with std Gaz setup and pushed hard they roll alot and feel a little unsettled.
Mark+Colin@MAC#1(01142511016) spent quite a bit of time on my geometry last year which made a fair bit of difference without compromising driveabilty
on the road.
That said it didnt solve the body roll which is in question here.....
Ive posted here,there and everywhere on different forums asking about spring changes to our setup.
Ive had a few answers on the subject and my findings are as follows:
Car needs an anti-roll bar fitting(mine is in dock now being fitted, will report back next week)
Other Tiger racing series guys also use one.
Spring changes help but will unsettle it on the road if you go too far.
Again chap in Tiger series uses 400lbs up front and something daft on the rear too but apparently it hanldes great in the dry but like tea trolley in
the wet.
Tiger tell me that you need to increase at least 40lbs per spring to actually feel the difference so ive had 4 made, 320lbs up front and 250lbs to the
rear(which is where it rolls most,see photo). These arent fitted yet but am holding out till i see the effect of the roll bar first.
I`m glad its not just me.....
http://www.youtube.com/watch?v=ajlF4nWJtGA
bi22le
posted on 19/5/11 at 11:52 AM |
As said above really. Its the spring weight you need to change, the damping stiffness essentially affects how quick the car will roll not the amount
of weight needed before it will start to roll. Anti roll bar will certainly help.
Your car is a common car and engine I would guess so you should have a common weight overall. This means you can use other car setups as a guide but
not gospal. Your trying to get an improvment not the perfect set up at the moment.
Good luck and feed back the results. This is a road that I will be going down shortly. I think I will just take my car to RTR though and be lazy!!
Biz
Please read my ring story:
procomp
Hi
The problem with the Tiger front end is that the damper is in a position where a 400 Ish Lb spring may sound high but it is only equivalent to
something like a 300Lb fitted on a Westfield for instance. If your dampers are running full hard then they are clearly either not set right or not
valved for the application. Either way the damper and spring package need further investigation before you spend money on a Anti roll bar.
The fitment of a anti roll bar is not necessarily there to eliminate the body roll but is there to act a a fine adjustment tool to give adjustable
balance to the car. Hence the reason why many end up fitting bars that are way to stiff for the application and are still way out on the spring and
damper package.
Cheers Matt
lsdweb
posted on 19/5/11 at 11:55 AM |
I know how you feel.....
![](/galpreviews/WYNMARTINI.jpg) ![Martini High Res](/gallery/WYNMARTINI.jpg) Martini High Res
Sorry for the non 7 hijack :-)
laptoprob
posted on 19/5/11 at 11:56 AM |
Interesting Matt......
By the sounds of it you`ve seen a few Avons then?
What spring poundage have you used to good effect previously then?
[Edited on 19/5/11 by laptoprob]
posted on 19/5/11 at 03:02 PM |
One thing car builders are not always aware is the relationship between roll stiffness and a handling balance, if you stiffen the rear without
altering the front stiffness by the same percentage change you transfer grip from the rear to the front ---- ie the handling balance tends more
toward oversteer.
Keeping it at its simplest level when making a change in roll stiffness at only one end of the car:
Stiffen front spring rate ----> Understeer
Stiffen front ant-roll bar ----> Understeer
Soften rear springs ----> Understeer
Soften rear anti-roll bar ----> Understeer
Stiffen rear spring rate ----> Oversteer
Stiffen rear anti-roll bar ----> Oversteer
Soften front spring rate ----> Oversteer
Soften front anti-roll bar ----> Oversteer
That's the general principle but keep in mind other factors such as roll steer and camber come into play that means these rules of thumb
can sometimes get turned on their head.
Altering the damper stiffness is used to alter the car balance in transient changes in steering input.
laptoprob
posted on 19/5/11 at 08:36 PM |
After speaking with Matt at Procomp i think you need to give him a call.
He certainly knows his stuff and has shed alot of light on my handling woes
Thanks again Matt
laurencedawson
posted on 22/5/11 at 06:12 PM |
Thanks for the replies guys,
Handling is not an issue-very neutral through fast corners, and fully adjustable on the throttle,
Admittedly a bit too much understeer into slow corners, then good fun oversteer on the power from
Apex to exit. Actually responded to changes in tyre pressure and shock changes too,
I used to race fford at a very amateur level many years ago, so I am quite used to stiff
Cars which bite when you get to the limit, and the Avon is really pretty easy to drive at and over the limit,
As I say I was really surprised when I saw the pictures, which doesn't say much for my test driver ability!!!
Some great advice which will give me a starting point, I don't know what the spring rates are at the moment,
They are the standard springs supplied with the car by tiger, it sits down quite a lot when you get in so must be fairly
Soft?
laptoprob
posted on 22/5/11 at 06:29 PM |
The springs you have are 250lbs at the front and 180lbs at the back.
laurencedawson
posted on 22/5/11 at 06:52 PM |
ok, so probably a too soft from what people are saying- trying to attach a picture but struggling!
les
laurencedawson
posted on 22/5/11 at 06:59 PM |
lsdweb- brilliant!! i dont quite have that much roll, but not far off!!!
les
laptoprob
posted on 22/5/11 at 08:22 PM |
If you want to go stiffer on the springs then call Tony at YORKSHIRE SPRINGS in Rotherham as he is the one who manufactures them for Tiger
Just tell him what poundage and he`ll make `em for ya.
laptoprob
posted on 30/5/11 at 07:26 AM |
Just to report back.....
I had the antiroll bar fitted last week which was off an HPC Caterham but bent to shape my Avon.
It made a huge difference. I went to Bylton yesterday and had a fantastic day with the Mac#1 boys.
The handling has become an absolute pleasure, it kept on the toes of all the bike engined stuff without drama.
It balanced nicely on the throttle between under+oversteer. I knew exactly what it was doing all the time and roll has been dramatically reduced.
Blyon is a very flat course so Cadwell may be a different story but upto now the car is sorted
laurencedawson
posted on 30/5/11 at 10:09 PM |
Great info thanks, il give them a call-what spring rates did you end up using? And if I can ask, how much?!
Did you have to bin the gaz shocks?
On a side note, I did an experience day years ago at blyton park- Leicestershire?
Was it a test day or track day? I would love to do a track day there, quite a nice circuit as I remember.
laptoprob
posted on 31/5/11 at 08:16 AM |
I didnt change the springs in the end.
I left it with the same Gaz setup as yours!
The only thing fitted was the roll bar....major difference
Blyton has had a revamp by the new owners.
It boasts a great circuit and new tarmac now and costs very little.
http://www.blytonpark.co.uk/
Are you local?
Rob.
[Edited on 31/5/11 by laptoprob]
laptoprob
posted on 1/6/11 at 08:28 PM |
I`m selling my springs if you fancy changing yours?
HAVE A LOOK HERE
laurencedawson
posted on 2/6/11 at 07:19 PM |
hi,
I guess I would be looking for stiffer ones- or maybee go the same route as you and get anti roll bars.
what kind of shock settings and tyre pressures do you find best?
les
laptoprob
posted on 2/6/11 at 07:48 PM |
Its changed a little now with the roll bar fitted but i ran 8 clicks up front(left>right) and 6 on the back but i have reduced them to 5 and 3
now.
supercat
posted on 3/6/11 at 10:07 AM |
Rob,
Do you have any pictures / details of were you got the bar from? This is something I would like to do on my car.
Did you only do the front or rear as well?
James
emidas
posted on 3/6/11 at 11:12 AM |
Have been following your arb project with interest.
Do you have some approx dimensions please of the arb, especially steel size & bar or tube?
laptoprob
posted on 4/6/11 at 07:18 AM |
Supercat/Emidas.....
it was fitted by an engineer who is very much into Caterhams locally. Its actually off a Caterham HPE 1996 which he bent into shape my upper wishbones
then mad two pockets to sit it in which were welded to the wishbones. I dare say he would attempt another but will have to ask first.
Its gone into MAC#1 for brake upgrades to be fitted this weekend so i cant send pics or dimms until Monday but will do so then for you both,
Meanwhile you may want to talk to this chap LINKY as he was the gut i spoke to at Stoneleigh about the
whole project but unfortunately was too far away from me. He was very helpful and sent over some pdf`s to do some measuring etc so he could quote for
the ideal bar.
I will talk with my local guy this weekend to see if he wants the work.
[Edited on 4/6/11 by laptoprob]
