Author: Subject: throttle bodies
ali f27
posted on 21/5/11 at 03:19 PM Reply With Quote
throttle bodies
Hi which works best on duratec injectors direct to head original position or injectors in bodies either way i have to blank 1 off just wondered if 1 worked better than the other cheers Ali
lsdweb
posted on 21/5/11 at 04:25 PM Reply With Quote
Depending what ECU you have, you could run two sets - Get Dave Walker's engine management book if you haven't already!
Wyn
BaileyPerformance
posted on 21/5/11 at 10:17 PM Reply With Quote
We did some development work on a Hayabusa 08 motor with megasquirt and jenvey throttles, we found power went up with the injectors further away from the throttles, the conclusion was the fuel had more time to mix with air before it was drawn into the engine.
If i was you i would install your injectors in the positions further away from the engine
martyn_16v
posted on 21/5/11 at 10:53 PM Reply With Quote
It depends on the usage of the engine. Further away does improve the mix at high air flows, but when the flow drops at low rpm/part throttle the airspeed through the inlet ports slows to the point that the fuel will start dropping out of suspension and pooling on the inlet walls. Having the injectors firing more or less at the back of the inlet valves minimises this when you're just pootling around town, hence why most OEM setups have the injectors close to the head.
If it's a road car, then I'd keep them close to the head. As has been mentioned, you could have a staged dual injector setup if you wanted to get the best of both worlds.
HowardB
posted on 22/5/11 at 07:36 AM Reply With Quote
watching with interest as the staged two set route is one that I want to try,...
Howard
Volvorsport
posted on 22/5/11 at 08:34 AM Reply With Quote
megasquirt can run staged injectors .......
as mentioned above , F1 cars have the injectors placed as far away as possible to allow mixing time .
i believe the cosworth duratec setup with roller barrels , have the injectors close ish , and thats good for 300 bhp .
www.dbsmotorsport.co.uk
getting dirty under a bus
