Bigboystoys
posted on 27/5/11 at 06:23 PM |
Brake conversion advice
Evening all after some advice. I am changing my rear axle to an atlas from a Capri and while doing it decided to do a disc conversion. I have the weld
on brackets sierra calipers and sierra discs. I have just positioned everything in place and there is a rather large gap between the Caliper and weld
on bracket. I know you can expect to have to use spacers between bracket and Caliper but this is too much of a gap I'm sure. Any pics would be a
massive help.
phelpsa
posted on 27/5/11 at 07:45 PM |
They are usually designed to take the high offset 240mm Escort discs, are you sure they're meant to take the sierra ones?
Antnicuk
posted on 27/5/11 at 08:17 PM |
i used bolt on brackets with my atlas conversion. they are designed to replace the back plate from drum. Do you have a picture? Could you not weld
on the brackets in a different place?
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
Bigboystoys
posted on 27/5/11 at 09:05 PM |
Thanks for the reply's, I did look at the escort discs after i posted this post and the offset would cure the problem. As for welding the
brackets in a different place the brackets come pre shaped to give you the correct radial profile for the disc etc so i would need to make my own from
scratch. Phelpsa do you know the best place to get escort discs?
many thanks Sam
phelpsa
posted on 27/5/11 at 09:33 PM |
Local motor factors is your best bet, I think mine were about £12 each.
phelpsa
posted on 27/5/11 at 09:34 PM |
They are smaller diameter than the sierra ones though. Are the sierra ones the right diameter?
