Author: Subject: brake fluid level warn
Craig81
posted on 20/7/04 at 06:31 PM Reply With Quote
Hi all,
is anybody familiar with the luego loom. There are two black/white wires that go on the same terminal on the brake level switch. The instructions say to earth the other terminal on switch. Under the scuttle there are two more black/white which breack out in different places. One is for the warning light which also has an earth . this leaves one other. Any clues any body??
cheers
craig
posted on 20/7/04 at 06:47 PM Reply With Quote
Not familiar with Luego loom but the other wire on a ford loom would go to the handbrake warning light switch.
elitewiring
posted on 21/7/04 at 12:27 AM Reply With Quote
you should have two black/white wires that go in the same blade connector and onto one of the terminals of the brake fluid level switch, the other terminal on the switch should then have a wire linking it to ground (therefore when level low switch is made an earth path is given to the warning light).
then there shouald be another single black/white wire that goes to the single terminal on the handbrake switch.
regards matt.
Chris Leonard
posted on 21/7/04 at 11:51 AM Reply With Quote
and make sure your brake warning light is a (!) in a circle or it will fail the SVA
Craig81
posted on 21/7/04 at 05:12 PM Reply With Quote
thanks for replys,
still doesnt seem to make any sense to me as they tell u put the other terminal of warning light to eath as well!!!!!. all seems a bit wrong to me !!
