hootsno1
posted on 28/5/11 at 09:31 PM |
Just bought a duratec
HI all
I have just bought a 2.0 duratec im picking it up sunday afternoon and would like to now what else i would need from the mondeo for this engine and
what bike TBs and ECU would you recommend.
many thanks
Mark
[Edited on 28/5/11 by hootsno1]
If a little hammer won't fix it get a bigger hammer
BaileyPerformance
posted on 28/5/11 at 09:49 PM |
quote: Originally posted by hootsno1
HI all
many thanks
Mark
Megasquirt MS2, jenvey 45's direct to head, 200+BHP out of the box. I wouldn't bother with the bike TBs, the injectors are often too small
anyway.
The megasquirt can be built to drive COP or a Ford coil pack directly.
www.baileyperformance.co.uk
flak monkey
posted on 29/5/11 at 06:49 AM |
Omex ECU and R1 throttle bodies should do the job nicely. Or any 42-45mm set of throttle bodies
Use the injectors in the cylinder head rather than the ones in the throttle bodies. Gives a lot more scope later on. Just blank off the holes in the
throttle bodies where the bike injectors fitted.
Sera
http://www.motosera.com
hootsno1
posted on 29/5/11 at 07:43 AM |
Flat monkey do you now what year r1 tbs i would need please.
big-vee-twin
posted on 29/5/11 at 08:45 AM |
You want 2001 GSXR 750 ITB's they are 42mm same size as Jenvey, you can get a Manifold from FastDan on here he made mine and also get engine
mounting brackets from him as they are difficult to source at reasonable cost. Here's some pics
[img]
![](/galpreviews/Duratec engine bracket.jpg) ![Bracket](/gallery/Duratec engine bracket.jpg) Bracket
[/img]
[img]
![](/galpreviews/throttlebodiesduratec.jpg) ![Throttle Bodies on Duratec](/gallery/throttlebodiesduratec.jpg) Throttle Bodies on Duratec
[/img]
[Edited on 29/5/11 by big-vee-twin]
http://www.triangleltd.com
Stuart_B
posted on 29/5/11 at 08:53 AM |
hi there, i went with megasquirt and gsxr750 throttle boddies. but if i were to do it again, it would be with omex and a set of jenveys.
stu
FASTdan
posted on 29/5/11 at 11:35 AM |
I have a few sets of bike bodies (inc r1) in stock so can put you a manifold and bodies package together if that's the way you want to go. As
said I also supply engine mounts to suit the locost chassis.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
Longerr
posted on 1/6/11 at 08:23 PM |
Hi Stu,
I got a duratec and deciding the same thing as hootsno1, between bike TB or Jenvey or anything else that would be for a quite good price/power ratio.
Why would you go next time for omex and Jenveys?
Do you know what is the performance gain between bike ITB and Jenveys?
http://locost.webnode.cz/fotogaleria our build so far
Stuart_B
posted on 18/6/11 at 04:04 PM |
quote: Originally posted by Longerr
Hi Stu,
hi there, sorry for a late reply,
next time i would go omex and jenveys, simply because the tunning of omex would be easier to get done for me, and looks.
stu
Neville Jones
posted on 18/6/11 at 05:01 PM |
Hi Stu,
stu
Be careful who you go to to get the omex setup. There's one I know who I wouldn't give a proper racecar, or roadcar, but they probably do
a useable road setup if you don't want max power or optimum fuel economy.
Ask if they will map leaner than 14.7 on afr to get max power. If the answer is no, then bypass them.
Some engines need lean, others don't. If they flat refuse to try, then your money is wasted.
Nev.
