Irony
| posted on 10/6/11 at 11:54 AM |
Sierra Ignition Switch
I have been searching on here for a while and on the net for this but I can't find it.
On my Luego Looms I have a few wires all lumped together called ignition switch. On the ignition switch the is a quick connector that I assume is the
starting/charging/power connector (as its not on my swtiches steering column diagram). It has several cables coming out of it of various colours and
various thicknesses - some are quite thick indeed. Which cable goes to what on the ignition switch? What colours go where?
Also my kit came with the Sierra column and the trailing leads with it. It seem in some cases to me mildly haphazardly wired with some wires joining
others by stripping the insulation mid wire and then soldering in a spur connection. These then have a bit of black tape wrapped around it. I have
no experience but is this normal for a sierra loom? Seems a tad shoddy.
jollygreengiant
| posted on 10/6/11 at 01:55 PM |
Red is normally pemanant live.
Yellow is normally switched live auxilliary(s).
Blue is normally lighting.
Black (IIRC) is normally ignition switched.
Brown is earth.
Using the above works for solid only colours and for wirring wof non solid where the above is the colour of the trace colour in the wiring.
Uncertainty can also be checked by using a multi meter, one wire will feed in, one will ONLY give power when barrel in start possition, the others
will give power in postion 2 (started) with one cable only having power on position 1 (radio circuit)
Yes the normal way Ford join cables is remove some sheath, join calbes with crimp or solder, then a quick wrap of tape before all cables wrapped in
tape or other.
The colours I am quoting from memory so I could be wrong but I believe is generally right for vehicles of the Sierra age.
a.j.stehr
| posted on 18/6/11 at 02:44 PM |
Hi, im currently making my loom from scratch. I don't know if you have the same ignition switch as me but mine has four cables coming out.
Red - Goes to battery +ve
Black - 1st Ignition Aux
Yellow- 2nd Ignition Aux
Black/Blue - Starter solenoid
Black and yellow might be the other way around, but will check.
Hope this helps..
Ashley
