Author: Subject: Switch, what is it showing?
chris_psmith
posted on 11/6/11 at 05:09 PM Reply With Quote
Sorry for another daft question, i fitted this switch on the dash but no idea what the symbol is showing, i have ended up using it for the screen washer pump?
Chris
[Edited on 11/6/11 by chris_psmith]
HowardB
posted on 11/6/11 at 05:12 PM Reply With Quote
looks like a foot brake pedal,...
Howard
posted on 11/6/11 at 05:14 PM Reply With Quote
Yes, could be brake pedal test switch if the handbrake used doesn't have one built in...
chris_psmith
posted on 11/6/11 at 05:29 PM Reply With Quote
I thought brake pedal but can see no possible reason why you would want a switch to turn the brake lights on?
Chris
bigrich
posted on 11/6/11 at 05:36 PM Reply With Quote
Looks like its used to test the brake fluid level warning lamp on the dash
[Edited on 11/6/11 by bigrich]
chris_psmith
posted on 11/6/11 at 05:43 PM Reply With Quote
Hmmm, back to the wiring harness again then! Ta.
Chris
belgian2b
posted on 11/6/11 at 08:02 PM Reply With Quote
Hello,
could be there to show a foot handbrake is engaged ( like on mecedes cars)
Gerardo
chris_psmith
posted on 12/6/11 at 06:47 AM Reply With Quote
No foot handbrake on the car, thinking about this one in bed, i assume that the car has no live at ignition on that switches off at engine start, with the brake level being an on / off switch that means no way to test the bulb. So i assume this is to test the brake low fluid bulb so needs looping in with a live to the brake bulb?
Leaves me one orange rocker switch that is unidentified, i would have guessed at hazard lights but they are off a switch on the top of the steering column, any thoughts?
Chris
HowardB
posted on 12/6/11 at 08:11 AM Reply With Quote
what car did the loom and switches come from?
Howard
chris_psmith
posted on 12/6/11 at 08:42 AM Reply With Quote
Loom is completely home made so no reference to anything. Just re-did the wires so that if i put the switch on the low brake light comes on, tested the brake reservoir switch and that works as well so all good. Now puts me back to finding how the washer stalk switch works on the column (escort 2 i think), just can't find the wires it connects.
Thanks all, starting to make more sense.
Chris
