New Topic New Reply
Author: Subject: Rivet Length
adam_moore
posted on 23/7/04 at 10:08 AM Reply With Quote
Rivet Length
I'm just about to rivet the floor panel on my MK Indy but I was wondering what size rivets I should use?
Has anyone got a guide to what length rivets should be used with the thickness of the plates being joined?
I'm guessing the thickness is about 4-5mm? (2mm floor + sealant + chassis).
Cheers, Adam
DaveFJ
posted on 23/7/04 at 10:16 AM Reply With Quote
Depends on what rivets you are using.....
more info please
Dave
adam_moore
posted on 23/7/04 at 10:28 AM Reply With Quote
large head diameter pop rivets. Aluminium and steel material.
Is there a website anywhere with a guide to this sort of thing?
shortie
posted on 23/7/04 at 12:19 PM Reply With Quote
I used 4.8x10mm large flange rivets, bit about how to fit the floor on my site in the May2004 section here http://www.dewweb.co.uk/indyblade/
Hope this helps,
Rich.
Mix
posted on 23/7/04 at 01:34 PM Reply With Quote
This site is pretty informative,
http://www.prifast.co.uk/rivet.htm
Cheers Mick
New Topic New Reply
