Author: Subject: Fuel Lines
neilp1
posted on 18/6/11 at 07:14 PM Reply With Quote
Fuel Lines
What's the best fuel line to use. I was going to use copper. It is for fuel injection.
What sort of connections would copper use and where's the best place to buy?
Neil
lotusmadandy
posted on 18/6/11 at 07:18 PM Reply With Quote
I just bought a roll of 8mm copper from B&Q.
No issues at sva and non since.I am swapping to injection
shortly and am going to flush the lines and solder olives onto the
ends of the pipe,to keep the rubber hose on.
daniel mason
posted on 18/6/11 at 07:20 PM Reply With Quote
i got mine from halfords. its got the appropriate bs markings and was well priced.
big_wasa
posted on 18/6/11 at 07:51 PM Reply With Quote
I bought a role of 8mm hgv brake/clutch pipe and also soldered olives on. I P cliped it every 75mm. Over kill but it wont move.
daniel mason
posted on 18/6/11 at 08:13 PM Reply With Quote
75mm
you must have the patience of a saint!
AdamR
posted on 19/6/11 at 09:07 AM Reply With Quote
8mm copper/kunifer with brass compression fittings designed rubber hose ends:
Like here
The fittings cost a couple of quid each and are available from most caravan/motorhome shops. No soldering required.
[Edited on 19/6/11 by AdamR]
neilp1
posted on 19/6/11 at 02:41 PM Reply With Quote
Like here
Would these fittings meet the IVA approval for fuel injection?
posted on 19/6/11 at 03:45 PM Reply With Quote
Or use an 8mm brake pipe flaring tool to fut a flare on each end of the pipe before connecting the hose
