Doctor Derek Doctors
posted on 28/6/11 at 01:07 PM |
MNR Steering Column Assembly/Paddle Shift
Does anybody have any experience of the MNR Paddleshift kits or Lever shift kits listed on this page?
http://www.mnrltd.co.uk/index2.html
Also does anybody have any pictures of the parts you get or the systems installed?
Currently I just have a Sierra steering column and need to fit a gearshift but I'm open to either Paddle or Lever. I'm just wondering what
the MNR items are like as they do a complete kit with modified column, paddle shift and all the linkage bits and generally their cars are quite nicely
made.
I quite fancy buying the whole lot as a package and fitting it into my car as I'm struggling for time at the moment to design and then have
bespoke parts made.
Also on the 'MNR steering Column' what style is the connector on the lower end? I assume its not a Triangular Bar like a sierra?
edit: Just realised that I should have stuck this in the MNR section. Damn and Blast.
Cheers ears.
[Edited on 28/6/11 by Doctor Derek Doctors]
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
Davey D
posted on 28/6/11 at 02:17 PM |
i have the MNR paddle shift on my MNR.
The supplied parts were:
modified steering column with alu end boss to mount the paddle shift to
1x Paddle shift centre pivot with rose joints
2x paddles that bolt onto the centre pivot
1x gear change cable
Ive seen several different designs of paddles on MNR's, but the design i was supplied was absolutely crap, and bent out of shape due to the poor
design. It was the typical crescet/kidney shape, but with all the middle cut out making it very weak.
Also the powder coating on the paddles and centre pivot started to flake off all over the place where there was rust forming underneath after about a
year. Poor surface preparation?
in the end i went to one of my local profilers, and got a new centre pivot lasered out of stainless to the same design of the original, and the
paddles laseres out of Aluminium, but to a better design that doesnt bend.
bassett
posted on 28/6/11 at 05:42 PM |
Mine was like above i just remade the paddle to not have stupid holes to allow it to bend. other than that ive been happy as its pretty simple to put
together and works fine after 2yrs plus
