Author: Subject: dash blank wanted
RK
posted on 2/7/11 at 02:31 AM Reply With Quote
dash blank wanted
to canada. grp is fine. anyone got one they want rid of?
thanks...
James
posted on 2/7/11 at 10:04 AM Reply With Quote
If you're not bothered what you're getting...
I made mine from a piece of 1.2mm ali. Paper template with a lot of time spent arranging the clocks so they'd fit behind the wheel etc. etc.
I then covered it in vinyl.
The key (if you have IVA- I know you dont) is to roll the bottom edge to the 19mm radius (I think I used a fat broom handle) This helps you or your passenger from cutting into the tops of your legs in a crash.
1.2mm is a bit thin and it does flex more than I'd like... but you can re-inforce along the back of it if necessary.
I made the mistake of not roughening the ali before gluing the vinyl. It's important to 'key' the ali to give the vinyl adhesive a chance!
HTH,
JAmes
scoop
posted on 2/7/11 at 11:00 AM Reply With Quote
Hi. Try Julian at Aerodynamix. He is a very helpfull guy. Does some nice stuff in GRP and Carbon.
www.aerodynamix.co.uk
