Author: Subject: sierra vs cortina uprights
lord dave
posted on 26/7/04 at 01:12 PM Reply With Quote
can i use sierra uprights with that adapter from gts on book wishbones or is there other adjustments i need to make.
stephen_gusterson
posted on 26/7/04 at 01:24 PM Reply With Quote
you cant use book wishbones.
The bottom joint is different, (unless you get your sierra hubs bored by MK engineering).
Also, I doubt the pickup points and vertical difference between the upper and lower joints are the same.......
atb
steve
phelpsa
posted on 26/7/04 at 01:26 PM Reply With Quote
I would go with cortina uprights if you can can find them. They are lighter and need no adaption or different wishbones to fit. If you are using a sierra donor then obviously use the ones on that.
Adam
ray.h.
posted on 26/7/04 at 06:02 PM Reply With Quote
I have a spare pair of cortina uprights.
Make me an offer if your interested.
