Author: Subject: Compressor belts.
skodaman
posted on 8/7/11 at 09:49 PM Reply With Quote
Compressor belts.
Anyone know a good place to get a new compressor belt from? Rand Ingersoll compressor but has had a different motor fitted at some point. I was using it one on a 30m airline so didn't notice it was slipping on the motor pulley. On returning to my workshop found it a bit smokey and smelled of burning rubber. The old belt is slightly goosed.
Skodaman
Antnicuk
posted on 8/7/11 at 09:58 PM Reply With Quote
i just bought one for mine, looked on the belt and it had the measurement code, punched it into ebay and there was one on there for £6, got it and fitted it, all good
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
NigeEss
posted on 8/7/11 at 10:36 PM Reply With Quote
Take the smouldering remains to your local motor factors, they chould be able to
match it easy enough.
trextr7monkey
posted on 9/7/11 at 08:52 AM Reply With Quote
local agricultural engineers/ lawn mower servicing spot- they carry all sorts and should fix you up quickly, failing that the local bearing specialist.
atb
Mike
