Author: Subject: Radiator Fan Swtich - Which one?
IainL
posted on 11/7/11 at 11:43 AM Reply With Quote
I'm just about to fit an inline Radiator Fan Switch, but looking on the CBS website you need to now the temperature they should cut in at and cut off.
Therefore please could some advise me what cut in/cut off temperatures are suitable for a 919 Fireblade engine setup.
Thanks,
Iain
James
posted on 11/7/11 at 03:39 PM Reply With Quote
IIRC for my Pinto engine I went through the Haynes to find the switching temps for that, then found a VW switch of the same temps to fit my Polo rad.
cheers,
James
No. 67
posted on 15/7/11 at 04:01 PM Reply With Quote
I think the 919 runs best at about 90 degrees?
Neville Jones
posted on 15/7/11 at 04:27 PM Reply With Quote
If you've got a VW rad, then the VW switch will do the job.
The item I use switches on at 90c, and off at 82c. One of them I had was on at 98c and off at 88c, just can't recall which VW it came from.
I've got the wiring diagram somewhere.
Nev.
