david_hornet27
posted on 14/7/11 at 09:02 PM |
Zetec and Megajolt
Hi Guys,
I am in the process of converting my Pinto powered Seven to Zetec power. I already have a Megajolt running the Pinto and am wondering if the same
unit will power the Zetec?
I have a lovely Blacktop Zetec waiting in the back of the garage and now have everything I need for the conversion except the inlet manifold and
exhaust manifold (the most expensive bits) although I will probably fabricate the exhaust manifold to keep costs down. Hoping I won't have to
shell out for another Megajolt!!
Cheers, Dave.
big_wasa
posted on 14/7/11 at 09:29 PM |
It will work. Just rewire and remap.
david_hornet27
posted on 14/7/11 at 09:31 PM |
Thank you!
bbwales
posted on 14/7/11 at 09:45 PM |
I went from a 2.0Ltr DOHC to a Zetec, no re-wiring required and just fitted it and it ran, used Bike carbs though.
Regards
Bob
austin man
posted on 14/7/11 at 10:01 PM |
works fine im running a 1.8 with zx9 carbs no problems. As it happens I am taking it for a little spin tommorow and will return tuesday after a visit
to one certain 13 mile toll road in Germany
david_hornet27
posted on 14/7/11 at 10:16 PM |
Have a great time at the Nurburgring Austin! Very Jealous! And thanks for the help Everyone else. Was a bit confused as I have seen Megajolts
listed specifically for Zetecs on Trigger wheels. I guess this is is because it is listed as a complete kit and needs different/less additions than
the pinto kit.
mcerd1
posted on 14/7/11 at 11:18 PM |
^^ if you keep the zetec's own flywheel, then you can use its std. VR sensor location - so no need for the trigger wheel at all
other than that you'll just need a different set of plug leads withe teh big rubber boots on them (the std. ones for the zetec probably) and a
new map
[Edited on 14/7/2011 by mcerd1]
david_hornet27
posted on 15/7/11 at 10:17 AM |
This conversion is sounding easier and easier!! Thanks for that everybody, esp the advice about the flywheel as I have a 1.8 zetec one (lighter)
waiting to be attached.
posted on 15/7/11 at 10:48 AM |
1.8 flywheel is the way to go, you just need a mk1 Mondeo clutch and Capri (CT133) release bearing.
