Author: Subject: Various bits for sale following upgrades
Raymond Y
posted on 16/7/11 at 04:17 PM Reply With Quote
I am having a garage clear out and have the following parts for sale.
Sierra differential - Supplied by Westfield in 2004 as a fully reconditioned unit. Diff has now done 8,500 miles. Unit is an open 3.9 with flanged output shafts. - £175.00.
Westfield Roll Bar - Used black roll bar for SeiW with a few scuffs and marks. This is the type with a single bolt at each end. Westfield part No 4632122. - £55.00.
Fuel pressure regulator - Filter king with glass filter bowl. Carb applications only. - £15.00. Sold subject to payment
Fuel pump - Facet fuel pump. Carb applications only. - £35.00. Sold subject to payment
Front uprights, discs and hubs. - Pair of Cortina front uprights modified as per Westfield instructions plus discs and hubs. - £135.00.
Wheels - Set of 5 6Jx14H2 ET20 7 spoke alloy wheels fitted with 185x60x14tyres . Two have Yokohama C-Drive and two have Avon ZV3 tyres. All 4 tyres have more that 6mm tread left. Spare has Yokohama A539 with more than 4mm tread left. - £125.00.
Tyres - Pair of Avon ZV3 185x60x14 tyres with more than 6mm tread - £35.00 Sold subject to payment
Rear shocks - Pair of SeiW rear shocks supplied by Westfield in 2004. I believe they are Gaz P/N GPA1106 B12 D12. Shocks have done 8500 miles and are in good working order with no leaks. - £40.00. Sold subject to payment
Engine - 1800cc Ford Zetec Silvertop with twin Weber 40's and Alpha 3d ignition. The engine is a Ford factory supplied remanufactured engine (was like a new engine) supplied by Westfield in 2004. I have a letter from Westfield confirming this and that the engine was originally manufactured between 1992 and 1994 and therefore does not need a cat. The webers were new in 2004. The engine produced 147 Bhp and 130 lb ft of torque when set up on the rolling road at Northampton Motorsport in 2005 (graphs available). Engine has never missed a beat or burnt any oil in the 8500 miles it covered between 2004 and 2010 when I removed it. Engine does not include a clutch, a thermostat housing, a water temp sensor, an airtemp sensor, an alternator or a starter motor, as I needed these for my new engine. It does have the alternator mounting bracket. - £575.00.
All the above items can be collected or I will post / corier if possible at buyers expense. I can provide photographs of any item by email on request.
Raymond
[Edited on 16/7/11 by Raymond Y]
[Edited on 17/7/11 by Raymond Y]
stevegough
posted on 16/7/11 at 05:04 PM Reply With Quote
U2U regarding Tyres.
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
gregs
posted on 16/7/11 at 06:53 PM Reply With Quote
U2U re shocks
arrow-engineering
posted on 17/7/11 at 06:22 PM Reply With Quote
engine
u2u re engine. thanks
Raymond Y
posted on 23/7/11 at 09:14 AM Reply With Quote
Various bits for sale following upgrades - UPDATE
Raymond
dlatch
posted on 23/7/11 at 09:25 AM Reply With Quote
have you got a picture of the wheels raymond?
Raymond Y
posted on 27/8/11 at 04:49 PM Reply With Quote
Unsold bits now on eBay
