Author: Subject: swirl pot plumbing
AndyW
posted on 17/7/11 at 12:23 PM Reply With Quote
swirl pot plumbing
Just waiting for the swirl pot to arrive. Can anyone tell me please, what connects to the 4 connections n it. Which is feed in, feed out, return etc etc.
Swirl pot with 4 in/out tubes. Which pipes go to which, and if anyone has pic/diagrams then all the better.
A
Dan.
posted on 17/7/11 at 12:47 PM Reply With Quote
Link
[Edited on 17/7/11 by Dan.]
bonzoronnie
posted on 17/7/11 at 12:57 PM Reply With Quote
Here's a little diagram for you
Dan beat me to it :but thought I would post it anyway
AndyW
posted on 17/7/11 at 01:16 PM Reply With Quote
Thanks for the above, so as I understand it I need 2 fuel pumps? I have a fuel pump shown here at the rear of the car:
and then nothing yet in the engine bay. Do I actually need anything else??
Im getting myself very confused with this!!
fimi7
posted on 17/7/11 at 02:01 PM Reply With Quote
Not sure if that was drawn to scale, my low pressure pump is putting in fuel at the top, was trying to avoid any possibility of the high pressure pump pushing back on it.
To kind of head off the remarks, this is a mock up of mine, the wood will be replaced with Ali in a couple days
[Edited on 7/17/2011 by fimi7]
--- Ali
SteveWallace
posted on 17/7/11 at 02:54 PM Reply With Quote
Here's mine in the car, pipe layout as described earlier in the thread. The second picture is shows the low and high pressure pumps. The low pressure pump is needed to get fuel from the tank to the swirl pot. The high pressure one is between the swirl pot and the injector rail. Sorry that its not a good pic, the flash decided to stop working...
[img][/img]
[img][/img]
scudderfish
posted on 17/7/11 at 03:19 PM Reply With Quote
Think of it that you have two fuel circuits which meet at the swirl pot. One is fed by the low pressure pump and goes to and from the fuel tank. The other is fed by the high pressure pump and goes to and from the fuel rail. Both circuits have an in and out connection on the swirl pot.
franky
posted on 17/7/11 at 03:53 PM Reply With Quote
Looks very
However from the research i've done the swirl pots should be round and ideally with the 'ports' set at an angle to encourage fuel swirl and help remove air bubbles.
What effect do square pots have as they effectively become a tank.... don't they?
lsdweb
posted on 17/7/11 at 04:04 PM Reply With Quote
And here's my old setup - the two lines disappearing through the white glands are the hp feed to the hp filter/fuel rail and the return from the rail.
Swift Fuel
Swift Fuel
Wyn
cliftyhanger
posted on 17/7/11 at 05:57 PM Reply With Quote
the return to the tank definitely needs to be at the highest possible point. And the high pressure pump feed at the lowest.
Have heard it suggested that fitting a restrictor in the tank return can be beneficial, stops the low pressure pump working flat out all the time.
And yes, round with offset pipes best, but I suspect a square one will be nearly as good.
AndyW
posted on 17/7/11 at 07:45 PM Reply With Quote
So I need a low pressure pump aa well? Better start saving up a few more beer tokens
posted on 17/7/11 at 07:49 PM Reply With Quote
From your photo it looks to me like you already have a low pressure pump and not a high pressure ??
AndyW
posted on 17/7/11 at 08:07 PM Reply With Quote
Totally confuddled now. When i was at the factory the other week they used just the pump I've got, and a swirl pot with 4 in/outs.
Will call them tomorrow to find out exactly whats what!!
AAAARRRGGGGHHHHH
posted on 17/7/11 at 08:53 PM Reply With Quote
Any markings on your pump? Does it tick? if it does then it's a low pressure pump. Yours looks like a Facet low pressure pump for carbs
AndyW
posted on 17/7/11 at 09:51 PM Reply With Quote
Here are the markings I can find on the pump, not brill pic but it is late!!
posted on 18/7/11 at 06:45 PM Reply With Quote
A high pressure should put out around 3 to 4 bar whereas a low pressure would be around 0.3 bar , about 4 or 5 PSI
AndyW
posted on 18/7/11 at 09:25 PM Reply With Quote
Got it sorted. I was being daft and totally missing the point. The pump I have is "obviously" my low pressure pump which feeds the swirl pot. I then (about to buy) add my high pressure pump to feed the injector rail from the swirl pot.
Sounds like I know what Im doing
Thanks for all the reply's, and yes Mel your are right!!!
posted on 19/7/11 at 06:25 PM Reply With Quote
Glad it's sorted.
