Soichi_Sugano
posted on 20/7/11 at 04:32 AM |
Pinto Transmission Help
I'm having trouble with my Locost that was built from scratch. It uses the engine and transmission from a 1971 British Ford Pinto and 4 speed
transmission. The problem I've been having is the gears stick now and then. I've taken the covers off and shifted while I was looking at
and I didn't see anything obviously wrong. I'm just wondering if anyone out there could lend some info on the matter or if it's
happened to anyone else.
Macbeast
posted on 20/7/11 at 05:19 AM |
Is the clutch disengaging properly?
omega0684
posted on 20/7/11 at 08:48 AM |
can you be a little more specific? the gears stick is a little vague, do you mean the gear lever sticks and you can't get it out of gear when
you engage the clutch pedal or you can't get it into gear etc?
more info the better buddy!
All the best
Alex
Soichi_Sugano
posted on 23/7/11 at 05:52 AM |
yes the clutch is disengaging properly. Twice in the last week I've had to open up the top plates on the transmission and disengage reverse. If
pictures would help I have some of the transmission when I had it open last.
posted on 23/7/11 at 06:19 AM |
Have you tried another gear lever ?
Soichi_Sugano
posted on 23/7/11 at 04:10 PM |
No I haven't tried another one. I live in the US and parts for this transmission are almost nonexistent. I had to look for parts before when the
piece that holds the shifting arm in place cracked. I looked all over the web and tried every fellow grease monkey I know about parts with no luck. I
ended up having to have a replacement one made out of stainless steel. Oh, and I should have stated this from the beginning that this is my first time
working on a manual transmission.
