SausageArm
posted on 26/7/11 at 10:29 PM |
Mac#1 Worx ZX10R turbo - engine mapping results
I've been down at BigCC Racing in Wokingham yesterday and today to have the ZX10R engine setup on their rolling road.
Here's a video from early on yesterday of the car being ran up while the fueling is adjusted for the low boost setting of 6psi.
http://www.youtube.com/watch?v=3q7lKVkHoBk
The finished results from today are shown below, the blue line is 12psi and the red is 8psi. The graph is power and torque at the wheels
Sean at BigCC Racing was telling me he would like to map more kit cars, so if anyone is interested give him a call.
[Edited on 26/7/11 by SausageArm]
mark chandler
posted on 26/7/11 at 10:46 PM |
That's a lot of power, how did you control clutch slip?
Also the exhaust is from the opposite side, have you any photo's of the install
SausageArm
posted on 26/7/11 at 11:03 PM |
The engine has a lock up clutch kit fitted to it, which consists of a plate on the end of the clutch basket, this plate has weights attached to
pivots, as the engine rpm increases these weights are thrown outwards and because theyre attached to the pivots extra force is applied to the clutch
plates, which helps eliminate clutch slip.
You have a U2U Mark.
coyoteboy
posted on 26/7/11 at 11:10 PM |
What were your supporting mods?
eddie99
posted on 26/7/11 at 11:11 PM |
Wow thats a serious amount of power Me likey very much!
SausageArm
posted on 27/7/11 at 09:41 AM |
Supporting mods are,
Dynajet Power commander 3 with hub and map sensor
Adjustable cam sprockets
JE turbo pistons
Carillo con rods H beam
Cometic Head Gasket
APE billet manual cam chain tensioner
Muzzy lock up clutch
Modified stock sump pan
External oil filter relocation kit
Oil cooler (thermostatically controlled)
Intecooler
GT30R Race roller bearing turbocharger
321 Stainless headers
3" bore exhaust
Billet plenum with internal bell mouths
38mm Tial external waste gate
Bosch high horsepower competition fuel pump
Aeromotive billet fuel pressure regulator
INDY BIRD
posted on 27/7/11 at 09:56 AM |
hi i remember our zx10r turbo mk our results where 222 bhp @ wheels at 7 psi never ran any more than this as was well enough on the road and track,
but we wzs getting 280+bhp at 9psi,
will depend on temp conditions also and sixe of intercooler,
nice car to drive though and pulled like a bitch,
good luck and have fun,
the only issue we had in the end was the manifold craking at the the turbo flnage just be aware of this,
all the best and good results
SausageArm
posted on 27/7/11 at 10:07 AM |
Thanks for the info, what manifold were you using?
Also, who mapped your car?
BobM
posted on 27/7/11 at 10:35 AM |
Where are you taking this off from and what bits are you using? I want do to this with my ZX10R. Currently
got a custom machined take-off plate for oil cooler but it retains the standard filter.
Not very Locost but very BEC
SausageArm
posted on 27/7/11 at 02:48 PM |
The engine runs a remote oil filter relocation kit from BigCC Racing, as the standard filter location was right where the turbo needs to be, this is
the kit below
http://www.bigccracing.com/shop/product.asp?idproduct=302&source=thumb
To the remote oil filter plate I added a Peugeot 106/205/306 GTI XSI Mi16 oil cooler take off plate with thermostat built in, like the one in the ebay
link below
MOCAL OIL COOLER TAKE OFF PLATE PEUGEOT CITROEN RENAULT | eBay
I then piped up a 13 row oil cooler to the sandwich plate, you can see the oil cooler between the radiator and intercooler
hope that helps
INDY BIRD
posted on 27/7/11 at 09:35 PM |
hi ran a veloity racing turbo kit form the states manifold was part of the kit, but it broke 2 times,
TCS a local person to me done the tunning and he is a skyline specialst in tunning etc,
just watch your cooling with the rad in that position, i had the same set up and water temps went very high, couldnt get enough air through to it,
we ran a cossie 4x4 intercooler top mount in the end and was perfect intake temps and cooling then
car looks very good
