Author: Subject: pinto engine codes casting numbers
kehale
posted on 3/8/11 at 08:44 PM Reply With Quote
hi,can anyone id pinto casting numbers cast in block? 35020 205 85 HM 6015-B-A ,THANKS
Mark Allanson
posted on 3/8/11 at 08:49 PM Reply With Quote
the only numbers I can help with are the 205 which means 2.0l with larger mains, usually injection, usually unleaded head.
The 85 means the casting was first used in 1985 which seems to be a contadiction with the 205!
DRC INDY 7
posted on 3/8/11 at 08:58 PM Reply With Quote
The 1st 2 letters of the engine number tells u the yearmonth the engine was made
Puddle Dodgers Club
Mark Allanson
posted on 3/8/11 at 09:25 PM Reply With Quote
That is a casting number, not an engine number
mcerd1
posted on 3/8/11 at 10:35 PM Reply With Quote
if its got a "205" mark like these:
Pinto - 205 block
Pinto - 205 block
pinto - 205 block
pinto - 205 block
this its the later/stronger 2.0 injection type block (i.e you can bore it out to 2.1 safely and its got slightly stronger conrods)
and as above the 2 letters at the start of teh engine code will give you the date when you look it up here:
http://www.burtonpower.com/tuning-guides/tuning-guide-pages/ford-manufacture-dates.html
(its easier to ID them this way than with the casting numbers)
[Edited on 3/8/2011 by mcerd1]
DRC INDY 7
posted on 4/8/11 at 06:08 AM Reply With Quote
I know thats the casting number thats why i said the engine number is what can tell you the year month
i was not very clear in what i said
ps the engine number is on the exhaust side near to the alternator and it is stamped on
Puddle Dodgers Club
