Author: Subject: Availabilty????? CLEAR GPS SPEEDO
PuppiesBalls
posted on 4/8/11 at 02:01 PM Reply With Quote
Ive been searching the web but cant find anything!
Looking for a GPS Speedo, which is really clear & can bee seen easily in daylight from a couple of feet away....
Something like this
Has to be GPS..
Do they exist?????
kipper
posted on 4/8/11 at 03:53 PM Reply With Quote
Well that sounds like a better Idea than gluing bloody magnets back on to the propshaft every few hundred miles.
I will watch with interest.
Denis.
Just a thought !!! what happens in tunnels?
[Edited on 4/8/11 by kipper]
Where did that go?
HowardB
posted on 4/8/11 at 04:43 PM Reply With Quote
I have three, two I use are designed to be camera alert systems, the easiest to read is the Road Angel professional connected, and it has the advantage of alerts too.
in a tunnel,.. use the analogue speedo,...
hth
Howard
posted on 4/8/11 at 04:46 PM Reply With Quote
I think you know the answer! You'd also have to wait quite a while for the GPS to reacquire the satellites when you switch it on.
iank
posted on 4/8/11 at 05:41 PM Reply With Quote
And for the avoidance of doubt they won't pass an IVA, but I assume this isn't an issue for the OP.
is using a smartphone a possibility
e.g.
http://www.appbrain.com/app/gps-speedometer/com.CharSoftware.GPSSpeedometer
http://www.appbrain.com/app/gps-speedometer/com.linxmap.gpsspeedometer
http://www.appbrain.com/app/ulysse-speedometer/com.binarytoys.speedometer
etc.etc.
Anonymous
PuppiesBalls
posted on 5/8/11 at 12:58 PM Reply With Quote
Thanks for the replies, I was looking for something more 'fitted' as apposed to something which youd stick to the window screen ?
